I'm looking at getting this board or maybe the crosshair hero, undecided.I`ve had this board for a few months now and I`ve had no issues at all, I`m on bios F13a now and I haven`t had a problem updating them, I would definitely buy this board again.
It`s a good, well built board, you don`t realise how much there is to it until you hold it in your hands. Poeple were saying how expensive the AM5 boards were but compared to my old Z390 board there is a lot more to it and kind of justifies the extra cost. What tipped it for me over the other boards I`d shortlisted was the PCIE lanes, it was the best choice for the price at the time.I'm looking at getting this board or maybe the crosshair hero, undecided.
Have had a look in the manual and the closest thing I can find is C0-CF Reserved. Debug LED under Regular Boot.Hi I have built my system but got a c5 error so can’t get into bios I have removed ram and tryed in different slots, does anyone have any ideas on this.
Hi mate it’s 7950x3d which I built up last night I flashed bios to f12 before I built it up through qflash on the back of the board with no cpu or ram in so don’t know what bios was originally on the board.Have had a look in the manual and the closest thing I can find is C0-CF Reserved. Debug LED under Regular Boot.
From having a quick Google. I would guess it may be memory related, which doesn't surprise me.
Also, what CPU are you running on the board and is it just x2 RAM sticks?
I have encountered many issues with RAM and stability and have also failed to POST on occasions, especially when flashing the bios.
When I couldn't POST the only way I could get it to come back is by using the EZ flash with USB stick on the rear IO. Had to rename the file to GIGABYTE.BIN or it wouldn't work though.
That's my only experience with the board failing to POST and only thing other than clearing CMOS I tried that got me back into the UEFI.
Hope you get it sorted!
I checked the qvl before I purchased em and it’s on the list so thought all would be fine but sadly not.I wouldn't claim to know too much about this particular issue but I have had similar issues but being stuck on code 15 memory training or code 00 reserved (unknown code.)
It sounds as though you have done the 'correct' thing in the first instance. This is exactly what I did when got the 7900X and Master board last November.
I guess I would start with things I could do, such as check my RAM is on the QVL for that motherboard. I know it's not accurate, but can help.
I think I would probably also, keep clearing the CMOS and flashing different BIOS to it as well to see if that kicks it into gear.
Other than that and checking cabling is all in order I would just Google the hell out of it for people with anything looking like similar issues.
Having a random 1 stick of other DDR5 would come in handy as well, even if it's not 'supported' at EXPO etc.
Reddit - Dive into anything
www.reddit.com
X670E AORUS MASTER (rev. 1.x) Support | Motherboard - GIGABYTE Global
Lasting Quality from GIGABYTE.GIGABYTE Ultra Durable™ motherboards bring together a unique blend of features and technologies that offer users the absolute ...www.gigabyte.com
I have a watercooled system too, so know exactly what you mean.We’ll just an update i tryed to use qflash plus to change to a new bios and I found out this doesn’t work when cpu is installed so I had strip down
My custom watercooled system which is a pain the **** to do and then take out cpu then I used f10 and it worked so happy days.
Thought all was fine no I have an issue with when I do a restart my monitor doesn’t wake up and have switch off from power supply which not allowing we to install windows due to the monitor not waking.I have a watercooled system too, so know exactly what you mean.
Strange, that was the only way I could get my system to POST using q flash with my system completely built in the case. Just needed to rename the USB file or it wouldn't flash.
Sounds like you have had progress though, so happy to hear that! This current generation is so particular.
or possibly having a laptop also keeping the monitor turned on plugged in. Not a long term solution, but maybe so you can sort power options/download monitor firmware. Just thinking.Have you tried plugging the display cable to the motherboard rather than the GPU and starting the PC?
Glad to hear you are up and running. I have an old X170 board with a 2600X that I repurposed this weekend into a media PC and had literally no issues and it boots in 14.9 seconds every time. Simpler times!Managed to sort it was a dodgy riser cable connection that was casing the problem.
Hence why we all got smartphones dohThat’s fine unless you need to perform troubleshooting with the motherboard and it’s your only PC.
Yes, you can use your phone to view the manual but still, not ideal.
I’ve got 4 computers in total and I’ve still read the physical manual several times.
