- 24 Jun 2021
- Oxon
big list of issues, chromium one is annoying me a lot
Do you have hardware acceleration off?The bright image when scrolling on a YT video then dark when you stop does seem to have been fixed since Chrome did their last update. But my biggest issues with all 54 based drivers at the moment on my 4090 is scrolling web pages in Chrome or Edge, it's horrifically stuttery, it's as if VSYNC is off in the browser and it looks and feels like it's running at between 40fps and 120fps when you use the middle mouse button and try auto scroll down, it's supposed to scroll very smoothly and always has done. DDU does not fix this, but the moment I installed any driver version that's 537 and older the browser performance is silky smooth.
Never experienced a bug like it.
Pretty sure they all have roughly that many open issues.
If none of them effect you then there is no reason to be concerned
... Nvidia better driver support...myth..Anyone noticed the new entry in the Nvidia control panel ?
"In driver 536.40, we implemented a new method to allow an application to use shared memory in cases that exhausted the GPU memory. This enabled applications which previously crashed when running out of GPU memory to continue to run, albeit at lower speeds. The switch to use shared memory occurs when running close to maxing out GPU memory to allow for a seamless transition.
Stable Diffusion happens to require close to 6 GB of GPU memory often. This can cause the above mechanism to be invoked for people on 6 GB GPUs, reducing the application speed. In driver 546.01 and above we added a setting to disable the shared memory fallback, which should make performance stable at the risk of a crash if the user uses a setting that requires more GPU memory. This guide will explain how to do this."
New Studio driver out matching new GRD, just how I like it![]()
Is there actually any difference/advantage to the Studio v GRD?
Studio driver undergoes more extensive testing for stability due to them being geared at the production environment market - The version being the same as GRD means all the GRD features are there, with the advantage of proven stability for production work applications that use the GPU (exactly my field). Nvidia provide papers on just how much testing is done and it's quite extensive.
You can use GFE to switch between drivers easily too, so if a new game comes out and a GRD is out for it, then just install and off you go, no need to uninstall Studio/old GRD, just on top and choose clean install. That's what I do if a GRD comes out and a Studio version matching the GRD version is not out on the same day.How do Studio Drivers differ from Game Ready Drivers (GRD)?
In 2014, NVIDIA created the Game Ready Driver program to provide the best day-0 gaming experience. In order to accomplish this, the release cadence for Game Ready Drivers is driven by the release of major new game content giving our driver team as much time as possible to work on a given title. In similar fashion, NVIDIA now offers the Studio Driver program. Designed to provide the ultimate in functionality and stability for creative applications, Studio Drivers provide extensive testing against top creative applications and workflows for the best performance possible, and support any major creative app updates to ensure that you are ready to update any apps on Day 1.
