The U6-Pro has a Qualcomm chipset and the LR/Lite etc. have Mediatek which is just not as good.I see people sll recommending th u6 pro over the others but dont see the reasons..
Is there a cheaper version than the U6-Enterprise supporting 6Ghz band.?
Also has anyone tested U6-Enterprise with Quest 3 for PCVR streaming.?
And last but not least if the U6-Enterprise is the cheapest 6Ghz UniFi access point what is the lowest price people seen it at.?
Really appreciate all the answers.No.
I haven’t but it works fine with other WiFi6E clients so I can see no reason why it wouldn’t work just fine. Bear in mind that you have DSR rights so if you order it, carefully unbox it and it doesn’t work as you’d hoped, you can send it back.
Yes, it basically is the cheapest and retail, it’s as cheap now as it has ever been because the pound is OK against the Euro at the moment. You should be able to get one well under £300 delivered.
Only tested in the house and garage so far but they're bloody bright. Plus one ecosystem to manage, and they can be paired with the cameras so pretty neat. But yeah, they are not cheap!Been interested in protect lights myself, but £££
Their addition means I can finally make use of a US-8-60W which has been sat in my tech drawer of unused stuff for some time, pretty sure I have another around somewhere.
and certainly haven't sold it. It was replaced with a US-8 as I didn't need PoE for where it originally sat. My garage isn't connected to the house, so it'd have to be via a WiFi Mesh.The front of the house is covered by a G4 Dome in the soffit and G4 Doorbell, however I wanted the driveway/front of garage covered. G5 Bullet arrived today along with some protect lights which I will fit another day. Will need to make some minor adjustments but very happy with the quality. Ideally it should be higher but there's no other way to approach without first being captured by it.
Draw a picture of your network and post it.Any suggestions.? Could it be caused by some setting.?
Are all the switch ports 1 Gbps? Have you checked the AP using the Network Controller to make sure that it's also 1 Gbps?This is how it is connected at the moment where before I had my pc connected to the other switch (without poe) but it didn’t make any difference.
Yes it is connected at 1Gbps.Are all the switch ports 1 Gbps? Have you checked the AP using the Network Controller to make sure that it's also 1 Gbps?
Unlikely, once it's set it's set.Could it be that it was still setting itself up earlier as I just added it to my network.?
I just realised that I actually changed 6Ghz transmit power to max which is probably why it improved.Unlikely, once it's set it's set.
Turn off nightly channel optimisation and use a wifi scanning app to ensure there's no overlap.
Not having it installed properly on the ceiling ins't going to help.
You want transmit power to minimum ideally.I just realised that I actually changed 6Ghz transmit power to max which is probably why it improved.
Any suggestions on Ethernet cable for this one.? I need probably 10-15m and it will be connected to 2.5Gbps network.
