Funnier than that, rumour is the 4080S is still 16GB and only an increase of 500 cuda cores!!!!Wait so the 4070 Super is still 12GB?
It’ll be DOA if it comes in at just 5% faster and costs £1200, personally I wouldn’t pay more than £800 and even then that’s not a great deal with new cards then less than a year away.I would laugh (very sadly) if they phased out the 4080 and replaced it with a £1200 4080 Super which was like 5% faster![]()
I think this is the stunt they will pull though tbh. They will dry out the normal versions supply allowing a bit of a haircut to those prices. The new refresh stuff will just prolong the launch prices. Happy if they actually discounted properly but cant see it.
I think people forget the ampere prices in the final year were cut quite a bit, the 3090 was cut to £950 the fully unlocked 3090ti that launched for £2000 was cut to £1150 after a couple of months and the 3080ti cut to £850 so anyone who pays full price for the supers will probably feel hard done by come the end of the summer when I expect Nvidia will discount the higher end to make way for the 5000 series.I think this is the stunt they will pull though tbh. They will dry out the normal versions supply allowing a bit of a haircut to those prices. The new refresh stuff will just prolong the launch prices. Happy if they actually discounted properly but cant see it.
Last I saw it was still 16GB, but with the wattage increase also rumoured it may be 20GB (which would need a 320bit bus thereby increasing power consumption). All up in the air as usual...I thought the rumor for the 4080s was a 20GB card
The 3090 FE never was sold at the reduced £950 price as they never had stock of them after the £1400 price and was only the 3090ti available and had its price slashed later as it was nothing more than a 3090 with silly power use and the silly new power connector and a stupid MSRP from day one and should have been no more than a £100/$100 more than a 3090.. but Nvidia testing if they can sell £2k/$2k gpus while the world was a mess and mining. So the fake price drop really wasn't true as you can price a product anything when there is none to sell, as Nvidia did.. and AIBS never sold them at the reduced price too as there again was none in stock or any that were never were priced lower then the original MSRP.I think people forget the ampere prices in the final year were cut quite a bit, the 3090 was cut to £950 the fully unlocked 3090ti that launched for £2000 was cut to £1150 after a couple of months and the 3080ti cut to £850 so anyone who pays full price for the supers will probably feel hard done by come the end of the summer when I expect Nvidia will discount the higher end to make way for the 5000 series.
I do remember the 3090Ti as you mention was slashed heavily, however I also remember 10GB 3080's were still going for the same as a 12GB model and barely dipped under the £800 for more AIBs. The problem for nvidia is its getting closer to the next gen as each month passes so as you say unless they do apply some heavy tactics they will be slow movers off the shelves and be like the Turing stain all over again.
I built a sim rig around a 4080 (for someone else) and discovered the memory bandwidth was the bottleneck on that card.I thought the rumor for the 4080s was a 20GB card
On a Reverb G2, I could crank all the setting up to max except for one: AA.
Maxed everything with medium AA was rock solid 90FPS (headset refresh rate) and the card wasn't even even working that hard. Max AA? Nope. 70-ish FPS relatively steady too.
The 4080 needs more memory badwidth. If the 103 die could handle a wider memory bus, I would be fine if the 4080 Super/Ti just got 20GB of ram with the wider bus that supports it. (And no other performance improvements)
I think there are export issues (or at least a fear of future export issues) with the 102 die. The US government is really trying to slow China's AI advance and the 102 die seems to be caught up in it.It will have to be on ad102 to be 20GB.
