- 28 Mar 2004
What was your initial quote from octopus before survey?
I've dropped our water storage start up temp from 46° to 44°. Max is still set to 50. I'll see how it goes.We've got a 300l cylinder, we had originally asked for a 210l but I'm super thankful that, by luck rather than judgement, we ended up with the larger one.
I've dropped storage temps to 50c with a 7c drop pre recharge - will see how we get on with that.
The water is allowed to cycle 24/7, with individual room thermostats dictating heating - set back temps of 18c and living temps of 21.5c at the moment, I think current flow temps are around 30c based on the weather compensation.
This shouldn’t happen. The pipe work should have a 3-port valve, splitting the flow to either the cylinder or the central heating system. It shouldn’t be a single loop. Can you see this in your system?One thing I keep meaning to ask about is that when there is demand for heating in the house, the temp in our hot water tank drops. I don't know if this is normal. I asked the service engineer last time it was serviced and he wasn't sure.
But it very much looks like heat is being pulled from the hot water tank when the UFH is on. Has anyone else noticed this in their system?
How much was your electricity?Here's our weekly flow and return averages, currently the home is on a 19.5c daytime setback temperature and 21.5c 4pm - 9:30pm
On Sunday we used a lot of hot water due to spring cleaning the place, which is why there's a water temp and flow/return anomaly.![]()
Would you be able to state who the independent was please?Ended up going with an independent.
Same spec heatpump, rads of my choosing and I get given all the pipework design sheets etc.
Same price as Octopus (with BUS) but install in January.
Do you have a smart meter?Not had our quarterly bill yet, but I've put together a little Excel spreadsheet to give ourselves an idea of running costs.
Between the 2nd and 6th of November we used 86 units, charged at 11.13p per unit - £2.39 per day. I've still got efficiency gains to be made with sorting out loft insulation, and wrapping all exposed/non insulated joints with this stuff - https://www.amazon.co.uk/dp/B0BZMTD8RL?psc=1&ref=ppx_yo2ov_dt_b_product_details
Hoping to lower the temperature compensation curve of the heat pump flow rates with these marginal gains, and maintain a lower constant flow rather than cycling which is no doubt costing.
For the 21 days I've been monitoring the heat pump meter, we've used 405 units, £45.08 worth - the first few days were more expensive per day due to higher flow rates/stored water temps. Ideally I want to be spending ~£2.50 per day on the coldest days.
Presumably you still have a smart meter for your electricity though to get your average rate down to 11p per kWh? Batteries too to allow you to use it during the day?No, not a smart meter. It's a separate metre for the heat pump and related ancillaries so I've just been taking regular meter readings.
Jem Energy - https://www.jem-energy.co.uk/Would you be able to state who the independent was please?
I spoke to a service engineer (and sent him graphs of the flow temps) and he agreed something is awry, so he's coming to investigate. It's due for a service soon so we'll do both at the same time.@b0rn2sk8 @Coran thanks. that makes sense. I'll see if i can track down a zone valve in the pipework.
I have a feeling this has been happening since the start. We've had the system for a few years but i only installed lots of extra temp sensors and emonPi and Home Assistant to record in the past 18 months, which has let me see in detail what's going on.
