installation from usb restart loop
29 Sep 2011
melee island
how do i stop usb installation boot loop when installing from a usb istallation?
hey, so I put the bios to start from USB, choose 64 bit , then it says loading files as usual, but when it does it's first restart after loading, it boots from the usb right away, instead of starting to install windows on my m.2, so then we are back to the choose 64 bit or 32 bit, then it gives 8 seconds before automatically choosing the 64 bit option, then it loads files, and goes back to loading from the usb after restarting the computer
I've tried setting the bios to load from the m.2 first, then the usb stick, but I have exactly the same problem
any ideas?
At the first reboot you can unplug the USB stick, or go into your bios and change the boot order to boot off your m.2 first.
Yeah as glanza said
Or press the appropriate F key
To change boot order without needing to go
Into the bios
Alternatively
Make the usb with different software
Or try different usb ports
Thanks man, this worked! phewy!! I thought I had the m.2 selected first, but by your prompt, I realised that I did not, now I know, the B-grade m.2, and B-grade RAM both work properly, splendid. thank you
