Interested to read your feedback @mrk
The D3045 was on my shortlist, but it's hard to source where I live.
My PC audio is the most ridiculous thing ever atm
1200€ RME ADI-2 into some 20€ Logitechs, or occasionally I'll use my Hifiman Sundara. Has to be said, you'll never hear 20€ sound so good..
Eyeing up either Genelec 8010 or iLoud Micro Monitors as an upgrade.
I looked at those, but they're too big. Working with a max height of 240mm (fit under monitor).
I bought some HD660S2 a few weeks ago and the laptop/audio interface I have wasn't driving them. Your review on the Topping + what I've seen online, made me purchase the DX3 Pro+. Total game changer for £200.Got the NAD
Not quite sure what to say other than how can NAD justify £699 for an all plastic solid state when this Topping is all metal, £219, and sounds on par?!
The really cool part is the remote can control whatever media is playing on the PC, and there are lots of settings to play with too. I like that it remembers the volume for both headphones out and speakers, so you don't have to faff around changing levels when plugging in headphones.
Like with all solid state amps, gotta leave it on for 30 mins so it warms up, that's when the sound is optimum![]()
My latest purchase is a S.M.S.L C200 DAC/AMP (£175)...
Sounds like a ground loop issue. I had similar with my G6 and schiit asguard. I purchased an if defender and issue solved.
See how you go I guess.Yea, probably. I would have said no, until the G6 started to do that constant noise over my speakers. Although I tested that very quickly, just using a cheap wire to hand, after having given up on the SMSL.
What's a bit odd is that I did try the SMSL C200 with two different PCs, with different plug sockets, USB leads, moving it around etc. And a ferrite core as mentioned. With the C200 I'd just hear the small pops and ticks between sounds on both PCs and only over headphones not with the speakers. I'd also hear the mobile phone signal (something I haven't heard in years). So hence my suspicion that anything that has an internal power supply is more likely to pick up static and noise in my setup.
Thank you for the suggestion. I did read on head-fi about the iFi Defender (& Silencer) and that might be my next route if the (likely) incoming Fiio K11 exhibits the same behaviour. There is a risk that the SMSL isn't at fault and the issue is my PCs but given it's so new and in a return window I'd think I'd rather just something else for now. At this point given my Fiio K5 Pro and G6 don't exhibit the same behaviour that makes me wonder.
I found a thread last night on headfi about solutions for eliminating USB noise and many of the solutions didn't look 'cheap'. One of the options was $175.See how you go I guess.
I had very apparent GPU noise from my setup until I stuck that in. Works like a charm. Probably over priced for what it is and I'm sure you can get something cheaper to essentially split the data and power.
Noise enters the DAC in two ways, either from the AC (mains) or from the source.
You need to connect your DAC using optical, as this will galvanically isolate the source input. There are also some galvanic USB isolation adapters if staying with USB.
It's also possible the noise you hear is coming from the AC mains. Do you have the DAC connected on the same power strip as the computer? It could be noise generated from the PC's PSU that's injected back into the mains (better quality PSU's solve this), then this noise entering into the DAC via the mains.
