- 23 Jun 2004
- Blackburn
Should buy your parts from the rainforest and return if the new part doesn't fix. Jeff's a good friend to have like that
That’s bad consumerismShould buy your parts from the rainforest and return if the new part doesn't fix. Jeff's a good friend to have like that![]()
That is one of things I tried early on, and unfortunately still was getting crashes.Don’t know if you have tried this before. Can you reduce your max clock speed to 2500. Try a few games and let us know how you get on.
Random black screens is a known fault of recent 7000 cards. It was supposed to be fixed in the latest Adrenalin drivers. Have you tried the Fluid Motion Frames preview driver to see if that improves things?That is one of things I tried early on, and unfortunately still was getting crashes.
One thing I've noticed this morning when monitoring temps is that currently the GPU is sitting at 56C while idle, and the Hot Spot at 66C.
Interestingly when I then try playing a game it ramps up but doesn't exceed 75C.
Meanwhile the Chipset is holding at around 67C
I’d also point them to this thread.Random black screens is a known fault of recent 7000 cards. It was supposed to be fixed in the latest Adrenalin drivers. Have you tried the Fluid Motion Frames preview driver to see if that improves things?
The only other thing I can think of is the vram- if this is bad then random restarts etc make sense. But this is very hard to prove unfortunately (happy to be corrected).
Why don’t you post in the CS section of the forum and see if they’ll take another look at your card?
Cheers I'll post something there and point them to this thread.Random black screens is a known fault of recent 7000 cards. It was supposed to be fixed in the latest Adrenalin drivers. Have you tried the Fluid Motion Frames preview driver to see if that improves things?
I hope thats under load, if not its still warm but its getting better, with regard to why your gpu is warm when idle all modern gpu's have a function called fan stop,
if the gpu drops below 50c the fans will turn off until the card is hit with a load, then when it goes past 50-55c area the fans will spin to dissipate the heat.
i'd have a quick look at case airflow and see if you can get a fan in the general gpu/chipset area and run it a bit quicker to allow fresh air to your board and gpu.
No that's while it's idle which is worrying me, as starting to wonder if that the cause of my troubles (though it doesn't really explain why I had the same crashes happen on the second pc)
I'm going add a couple new fans to my computer this evening to see if I can increase airflow to that area, and will also check if the fan is working correctly (there isn't any dust build up from what I can see)
Storage - 3xM.2, 2xSSD and 1xHDD
No the second pc was intel based and running a Z170 MBthe second pc you ran the gpu in, is that a similar x570 system or a intel based rig?
f it were me i'd take out 2 of the m.2's at the very least, check what speed the gpu is running at via hwinfo under load, it should read x16, any lower and your bandwith limited, go too low and it will cause major headaches and problems.
I would yes the sata based drives should be ok but try with only 1 m.2, if still no joy take 1 sata drive out at a time and test a game(s)Lane capacity confuses me somewhat, do you recommend reducing the drives further?
Sensor Properties: | ||||
Sensor Type | Nuvoton NCT6798D (ISA A00h) | |||
GPU Sensor Type | PMLog (ADL2) | |||
Motherboard Name | Asus Prime X570-Pro / ROG Strix X570-E/F/I Gaming | |||
Chassis Intrusion Detected | No | |||
Temperatures: | ||||
Motherboard | 54 °C | |||
CPU | 37 °C | |||
CPU Diode | 41 °C | |||
CPU Package | 41 °C | |||
Chipset | 72 °C | |||
PCH Diode | 72 °C | |||
GPU | 56 °C | |||
GPU Hotspot | 64 °C | |||
Samsung SSD 970 EVO Plus 2TB | 66 °C / 65 °C | |||
Samsung SSD 850 EVO 250GB | 46 °C | |||
CT1000MX500SSD1 | 45 °C | |||
Samsung SSD 970 EVO Plus 500GB | 53 °C / 60 °C | |||
ST3000DM001-1ER166 | 41 °C | |||
Cooling Fans: | ||||
CPU | 651 RPM | |||
PCH | 3355 RPM | |||
Chassis #1 | 564 RPM | |||
Chassis #2 | 399 RPM | |||
GPU | 614 RPM (15%) | |||
Voltage Values: | ||||
CPU Core | 0.984 V | |||
CPU VID | 1.000 V | |||
+3.3 V | 3.296 V | |||
+5 V | 5.020 V | |||
+12 V | 12.076 V | |||
+3.3 V Standby | 3.408 V | |||
VBAT Battery | 3.376 V | |||
CPU VDD | 0.981 V | |||
CPU VDDNB | 0.988 V | |||
GPU Core | 0.585 V | |||
Current Values: | ||||
CPU VDD | 8.31 A | |||
CPU VDDNB | 7.22 A | |||
Power Values: | ||||
CPU Package | 38.24 W | |||
CPU VDD | 8.16 W | |||
CPU VDDNB | 7.13 W | |||
GPU | 90.00 W | |||
Debug Info F | 65535 65535 65535 65535 65535 65535 | |||
Debug Info T | 00 00 00 | |||
Debug Info V | 36 00 62 62 62 FF FF (00) / FF FF FF FF FF FF FF FF / FF FF FF FF FF FF FF FF | |||
Debug Info I | FF D42B |
Cheers, will give it a goI would yes the sata based drives should be ok but try with only 1 m.2
That 2tb Evo plus is a bit warm, that a SSD or a m.2?
Its a M.2 which is located directly underneath the 7900 XTX.
It's around 20c hotter than it needs to be tbh, m.2's should idle around the 43-45c mark and then under load with a heatsink sit in the mid 60-70c region, there are a fair few controllers on the board that will take 1pcie lane, so I would say you have too many drives especially m.2's installed.
Also pcie gen 2 is pretty slow your drives and GPU are capable of gen 4 speeds.
