- 4 Aug 2007
- Wilds of suffolk
hhmmmm, what if I don't export, not done so really for a while.
If you do not normally export then you start at zero
Is that on Octopus? I signed up and enabled notifications but had nothing and apparently missed the first one that happened.Saving session tomorrow, found it by luck no email yet!
5-6:30pm
5-6:30pm
That's the plan I think, just empty it at full rate for the 90 mins. Should be worth about £28. It would cover my entire November electricity bill!May as well empty it anyway even if you wind up on grid after.
At previous one, it paid you £2 odd per extra kWh exported, which is about 6-7x what an imported unit costs after the session.
See my above baseline……i aint saving any, maybe worth looking into battery storage at some point.Saving session tomorrow 17:00 to 18:30 £4 per kWh!!!!!
Check a third party app like loop/bright and see if the dcc have the data.Anybody else got issues with there export data - mine only goes up to the 24 November??
Import is working*, as is gas, just not showing any export, and Octopus account shows "Hmm, looks like we are still processing the electricity readings from the last few days, so we can't show your progress for the week right now - best check back later. If this continues, get in touch."
Really need it to be working for tomorrow.
Just noticed the import only goes up to Friday as well, though live usage shows in the app (I have an Octopus Mini).
Problem with the app, as mine as been showing all day and now theres nothing.Good point, Bright is showing the import, including today, but I do have a Glow IHD from Hildebrand/Bright. It doesn't show export, but I don't think the Bright app does.
Digging around in the Bright App it does seem to be receiving data from the DCC, so hopefully just a glitch at Octopus - I'll give them a call tomorrow or try Twitter.
