Or you just bing in a used/remanufactured one like you’d do with an ICE car.
No one’s putting in a brand new battery into a 8+ year old EV. Even under warranty they typically use remanufactured packs.
Supply of packs isn’t the issue, it’s there accessibility and safety considerations of handling the battery packs.
Structural packs are going to be an absolute ass to change.
No reason if you are changing a whole pack the chemistry can’t change (as long as nominal voltage is the same)
For single cell replacement / partial pack replacement, Even though chemistry is changing, “older” Chemistry won’t become obsolete as they will have different applications. So will still be manufactured.
