Plusnet Discussion Thread
Man of Honour
20 Sep 2006
The short version is I do dev work at a company with an incompetent sysadmin. He frequently sets up rules that results in IP blocks of legitimate developer traffic and won't whitelist us, doesn't provide a VPN, blocks our private VPN, blocks datacenter IPs, etc. In the end the easiest option was to just get a home internet with a dynamic IP and swap it when his silly rules block it :p. Not too bothered about IPv6 at the moment.
Wow, what a douche. Doesn't your company use a VPN?
18 Feb 2008
When you ask for company VPN access and the 'sysadmin' responds with "what's a VPN" you know you're in for a good time. That's what happened here, I think it's one of the owners relatives who's good with computers :cry:
~cw
~cw
2 Jan 2019
I would go Aquiss for the great customer service (I am an Aquiss customer by recommendation of a colleague), benefit from the static IP and dual stack v4/v6, and just use NordVPN or some other throwaway VPN service with hundreds of UK nodes for connecting in to the incompetent sysadmin's systems. Could even split tunnel it so you could just leave the client running and selectively VPN only your dev traffic.
12 Apr 2007
I recently went from plusnet FTTC to FTTP..
It went smoothly to be fair.. Low ping and up/down speeds as advertised.
Not much more to say about it really!
21 Aug 2010
I recently did the same. Average ping increase of 1.5 using cloud fare speed test.
Service has been faultless but so was the FTTC. only really swapped because it was cheaper. The cabinet it in front of the house.
12 Apr 2007
I'm getting about 10ms with couldfare speed test (not used that one before) Ookla speed test, seems to vary between 10 -18ms, I don't think i've seen it above 20ms.
21 Aug 2010
Abouth the same then. I will be moving off on renewal but only because by then toob will be available. 900mb symmetrical for £25 I don't think can be beaten.
