Frame Gen goodness on your 2000/3000 series RTX!
Games such as Alan Wake 2, Cyberpunk, Ratchet and Clank, The Witcher 3 and many more
UPDATE AS OF 24TH DECEMBER
LukeFZ's AMD FSR 3 Mod To Enable Frame Generation Across All FSR 2 Games Has Been Leaked
OR ( This works better for me and easier )
dlssg-to-fsr3 (Replace Nvidia DLSS-G Frame Gen with AMD FSR3 Frame Gen) by Nukem
Installation
- LukeFZ's AMD FSR 3 Mod To Enable Frame Generation Across All FSR 2 Games Has Been Leaked, Supports Both NVIDIA & AMD GPUs
- https://wccftech.com/enable-fsr-3-frame-generation-in-any-fsr-2-game-mod-nvidia-amd-gpus/
Installation
- Download and extract the .zip file listed on the Files page such as dlssg-to-fsr3 ( recommended for most people ) or dlssg-to-fsr3-DLSSTweakEdition (ONLY IF USING THE DLSSTweaks Edition) located here https://www.nexusmods.com/site/mods/738
- Double click on "DisableNvidiaSignatureChecks.reg" and select "Run". Click "Yes" on the next few dialogs.
- Locate your game's installation directory. For Cyberpunk 2077, this would be the folder containing Cyberpunk2077.exe or for TheWitcher 3 C:\Program Files (x86)\GOG Galaxy\Games\The Witcher 3 Wild Hunt GOTY\bin\x64_dx12
- Copy "dlssg_to_fsr3_amd_is_better.dll" and the new "nvngx.dll" to your game's installation directory.
- Done. Launch the game. A log file will be created in the game's installation directory.
- If you're using EPIC launcher, there may be issues such as not working at all.. Only Cracked versions, GOG purchases, Steam Versions and Origin versions etc
- Nvidia Driver Updates : You will need to re-run/merge the DisableNvidiaSignatureChecks.reg file after updating Nvidia drivers!
- Flickering FIX ( OLED ) : To everyone else that has major flickering with your OLED in bright areas, you can either turn the sharpen down OR go into your Nvidia driver and enable DSR-Factors between 1.78X DL to 2.25X DL (DLDSR) which looks great with DLSS. This works perfectly in The Witcher 3 and Ratchet and Clank, but I haven't tried it in other games! https://forums.guru3d.com/threads/d...o-lock-to-60-fps-in-some-titles.449003/page-3
- GHOSTING FIX : Apparently, using the latest DLSS 3.1 you are more likely to get ghosting, however this is fixed in the older version DLSS 2.5.1. Back up your original DLSS and downgrade to 2.5.1 see if it fixes the issue Download : NVIDIA DLSS DLL 2.5.1 : https://www.techpowerup.com/download/nvidia-dlss-dll/
