- 19 Nov 2009
- Southwell
Anyone know when Hyte Y70 Touch cases will be In Stock??
I sent a ticket request in, they’re expecting supply’s to arrive early December according to manufacturer.Anyone know when Hyte Y70 Touch cases will be In Stock??
Loving my snow white one. Really easy to work in and the overall quality is excellent. I used to run a sensor panel so the screen is a massive upgrade to that.How are you guys getting on with the case then?
Looks great!Loving my snow white one. Really easy to work in and the overall quality is excellent. I used to run a sensor panel so the screen is a massive upgrade to that.
Hard to say really but before with old dry paste and a 240mm AIO I was hitting over 80C in some games and now it's hitting high 60's. Now have a 360mm AIO and new paste though but I've also got 6 intake fans so plenty of cold air coming in anyway.How you finding temps with the gpu blowing onto your mobo? Only thing putting me off this case is if the 4090 FE doesn't like being horizontal mounted.
Love that!Loving my snow white one. Really easy to work in and the overall quality is excellent. I used to run a sensor panel so the screen is a massive upgrade to that.
Yep it's a Deepcool LT720 360mm radiator but I swapped the fans for Lian-Li. It sits high up so you only see the fansLove that!
What cpu cooler are you using?
I’m assuming AIO mounted in the roof (hard to tell from the pic)
Got admit, that's one nice-looking case. The touch panel is so clear. Whats the resolution?
