- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Hi all,
Starting a PC build - looking to play mainly solitaire and use for a bit of Word letter writing, so thanks to all your advice I've gone with following specs, which apparently should be able to just about run them without too much lag:
Specs:
Plan is to build in walnut with some 3d printed parts to make things like fan mesh and the like easier to manage.
I've done some quick sketches of initial design, really to think about the airflow as a starting point for the components, so would be brilliant to get any thoughts/brains on anything I should adjust:
This is obviously just an initial mockup, I plan to go completely bonkers with my CNC and laser cutter on the final build, so it'll have all sorts of carvings and madness.... and probably some LEDs.....
Specs:
- GPU: RTX 4090
- CPU: AMD 7950x
- RAM: 96GB
- HDD: 4 x 2TB NVMe
- AIO CPU Cooler: 420mm - Liquid Freezer II
- Case Fans: ARCTIC P14 PWM PST A-RGB
