Thermal Compound
30 Dec 2021
Yorkshire
What's the best stuff to put under a water block and just forget about for a long time
i have some Arctic MX-4, but for the cost of thermal paste is there is somthing more trust worth?
CPU is only a i5 13500 so not massive heat output but i don't plan on stripping the system for a long time.
unless i can find a cheap 13600/13700 before i make the change to water haha
25 Oct 2010
MX-4 is fine, you'll see no real appreciable gains with more expensive paste, especially not on that CPU.
12 Apr 2007
The correct answer is to use whatever paste you already have laying around.
No need to buy more until you run out.
pre
pre
29 Oct 2003
London
For an old system what others have suggested MX4. For a new system/daily driver Honeywell ptm 7950 thermal pads.
