- 30 Sep 2005
This might help when talking to people about which setting to change.
Made things a bit "grainy". Is this what compression is, I wonder? Wish I'd written down the settings I used this afternoon. ne'er mind it's not too bad at all. Quite playable. I'll have another tinker tomorrow. I'm on annual leave. Time to play with my toys.
. On the other hand, now I'm seriously toying with the idea of splashing out on a 5800x3d to replace my 5600x. No way am I going to get a 4090 though. That rabbit hole is calling me but not loudly enough to drop a grand and a half on another gpu.
.Is this what compression is, I wonder?
Hi danlightbulb,Did you try setting it to 10 as I suggested? It will show you what compression is very clearly, then just change it back and see the effect vanish in front of your eyes. You can do this live in the Oculus link construct viewing your desktop in the headset, don't even need to be in a game to see the effect.
Picture was just as good with it set to 500 . (I reset debug tool after each change)Hi danlightbulb,
It's been a while since I fiddled with the settings in debug tool. I think generally I'm over trying to reach nirvana with current vr tech. Anyhow, I gave it a go this morning. Set the encode bitrate to 10. Maybe my eyesight is not that great or I'm doing something very wrong here but I couldn't see much differencePicture was just as good with it set to 500 . (I reset debug tool after each change)
I'll give it another this evening.
Its never overI think generally I'm over trying to reach nirvana with current vr tech.
