- 19 Oct 2010
Thank you.
I'm on IOG. As soon as I plug my car in they give me a 7.5p slot. No idea why but i'm happy to use it. Home today at 15:30. Battery down to 8% (because I manually exported it all earlier in the day). So for 2 hours i'll charge car and battery. Then dump battery from 17:30. Then charge till 19:30 and if battery is 100% start dumping again. Rinse and repeat tomorrow.
So far this month I've drawn 917.1 and exported 414.7. So a cost to me (plus standing charge) of £6.58. This saving session should put me in profit for the month. I've had 2 Octopus signups and my FIT paying PV has generated over a 100 units so far. That's worth over £50.
2024 could be a mega year for energy profit.
I don't get the IOG evening slots, but get the morning stuff, think because the car battery is only 12.5kWh.
Is it region dependent though? Do those cheap slots co-incide with powerups or any other event? or is it literally you plug in and bang its 7.5p?I'm on IOG. As soon as I plug my car in they give me a 7.5p slot. No idea why but i'm happy to use it. Home today at 15:30. Battery down to 8% (because I manually exported it all earlier in the day). So for 2 hours i'll charge car and battery. Then dump battery from 17:30. Then charge till 19:30 and if battery is 100% start dumping again. Rinse and repeat tomorrow.
Charger, through Zappi. request to be ready by 04:00 and then I adjust the car ready time through HA at 05.30, 07.30 and 09.00 to get the additional morning slots, but never had anything offered prior to 11pm.Are you on IOG with car intergration or charger intergration?
It could be region based, yes. The slots are allocated in 30 min chunks. Some times you'll get 30 mins and then a 2 hour gap and another 30 mins. recently (all this year). I am being given solid blocks as soon as i plug in. All charged at the 7.5p rate.Is it region dependent though? Do those cheap slots co-incide with powerups or any other event? or is it literally you plug in and bang its 7.5p?
My time of use tariff went to 9p!
Thanks Octopus.Remember when that might have been enough for a nice takeout, large kebab and chips just a couple of years ago.£6.40 for me, decent. Worth putting dinner off for half hour.
Hopefully no more sessions for a couple of weeks.I forgot to turn off discharge scheduleHopefully no more sessions for a couple of weeks.
45 Minutes of full discharge
EDIT
Actually its not that bad.
