The ones Autodoc tend to send are the standard Mondeo ones. I bought mine direct from Ford.or go to https://www.autodoc.co.uk/ enter your reg in and search Anti Roll Bar links, if you're in a hurry copy the OE Part Number and put it in eBay or Rainforest.Parts catalog FORD, original catalog FORD, online catalog FORD, Car catalog FORD
parts catalog FORD, original catalog FORD, online catalog FORD, Car catalog FORDford.7zap.com
Wrong ones, the ST220 ones are 225mm.Front or rear?
Edit: can see rear in title now.
What’s the length of the ones you have?
255mm here
For Ford Mondeo MK3 ST220 Febi Rear Anti Roll Bar ARB Drop Links | eBay
A faulty chassis constitutes a major safety risk – vehicles can lose wheel grip as a result of worn tyre profiles and, in the worst case scenario, swerve and cause serious accidents. Why this exclusivity?.www.ebay.co.uk
I'd ring Ford first, they still had them when I last wanted a pair, they were about £40 each.So am I best just getting adjustable ones?
Never had a problem with Autodoc and I use thrm at least once or twice a year.I don't trust autodoc and similar sites. They quite often list the wrong parts for performance models. They will fit but don't have the proper reinforcement.
It's gonna vary by car. If you order any ST220 suspension bits they won't be what you get. Shocks, springs, bushes, control arms, hubs, drop links.....all wrong.Never had a problem with Autodoc and I use thrm at least once or twice a year.
