Experience with Stance+ coilovers?
24 Sep 2020
Nott'm
Hi all,
The current coilovers on my skoda fabia have given up (crappy JOM things). I dont have mega money to spend on something mental so I've been looking at Stance+ coilovers as they seem a reasonable price.
Was wondering if anyone has had experience with how they are and if they've had them collapse not long after getting them. Im not too fussed about perfectly smooth ride quality as Ive got used to the bumpy-ness of the JOM coilovers.
Thanks
They're not really much different to jom
There isn't any cheap coilovers I'd personally have on my car, but likewise the price of coilovers seem to have gone through the roof recently.
The quality isn't going to be any worse than jom,
I can deal with similar quality, cause the JOM's have lasted me 3 years with quite a bit of driving and they were used when I got them cause I was in need at the time.
Might order them and see what happens tbh, cheers
Stance+ are terrible for ride quality though... and are you paying someone to fit them? If so replacing cheap coilovers every 3 years is going to cost.
AP are decent, much better ride and not massively more expensive if you can stretch to those?
They’re like driving on wood I took them off a car I bought as they were ridiculously stiff. I fitted a set of MeisterR ClubRace which have much more adjustability.
I think all cheap coilovers are going to give the same. You get the lows but at the cost of any level of comfort and ride quality. If you're ok with that, it's no problem.
Ill fit them myself, fitted the JOMs I had.
I could probably look at getting some AP ones, ill have a gander online at them. My main problem was a lot of brands like BC and KW are like £1k+ and I cant stretch that far :D
Yeah, KW and BC quite a bit more expensive - they also do ST-X, which are essentially KW v1 but without the stainless bodies; cheaper but still around £750. The AP's are around £550.
If you're on a budget good shocks with lowering springs are better than cheap coils, unless you don't care if your car behaves like a bouncy castle. :D
Ive ordered from Tunershop before. Got a set of Eibach Pro Street S coilovers there £250 cheapr than any UK supplier. Only caution i would have if any warranty claim you need to chip back to them in germany for them to then sort with manufacture.
I personally wouldn't go cheaper than something like BC coilovers, the el cheapo ones are pretty terrible to drive to the point of being dangerous if you need to take evasive action with how bouncy and unpredictable they are.
I know BC would be the best bet, but I just can’t justify spending on the coilovers what I spent on the car in the first place
Probably better going back to springs than cheap coilovers. Many aftermarket coilovers also need maintenance which is something to consider.
