When I see something that's not Good Year, Michelin or Continental on a performance car it immediately sets off alarm bells. What else have they skimped on if they can't afford good tyres?
There is also Yokohama, Bridgestone, Dunlop, Pirelli (though I don't rate them), but personally I'm happy enough with mid range brands. Some of which offer competitive performance oriented tyres at the top of their range too. Hankook for example. Nankang, Toyo, Federal, Gitti, etc, if we're talking semi-slick.
And I'm usually forced to go with some mid-range brand when I get tyres for the BMW because of the old tyre size. Usually it has to be Federal, Kumho, or Nexen. Or if I fit the 14" it has to be Barum or Firestone when I last checked!
But anything typically found in the "discount" brands section of a tyre website is a big no-no...
When it's from a dealer, that annoys me most of all. I get that anything spent is lost profit, but any real potential buyer will either want them changed before buying or will insist on a discount to give them money to change them almost immediately.
Agree 1000% with this. I've also had sellers argue with me when I say it needs a set of tyres because "they are brand new, I just fitted them!" because to them, a tyre is a tyre... But if I'm buying something 2WD with 300HP, why the absolute **** would I want to drive around with Dragon Man PlusPops. I'd rather you left on the Avons with 3mm of tread left because at least I know they'll get me home!
Avons, etc. have good enough performance for day to day road driving and used to be reasonably priced though I notice a lot of the very average at best tyres like that are now pushing up close to the premium brand pricing - which are much better tyres... hopefully that doesn't result in the higher tier tyres going up loads.
