Knife Thread
Suspended
27 Dec 2009
Something like this is a good place to start.
Good quality, no frills.
I second the recommendation for something from the Victorinox Fibrox range.
12 Apr 2007
Yeh agreed... Depends what you are comfortable with. 99% of the time I use a 14cm ulility/small chef knife or an 18cm Nakiri.
I'd suggest buying a couple of decent practical knifes rather than a full 5 or 7 piece set.
6 Oct 2004
Birmingham
Not sure if this is better in its own thread, but since there are a few posts on sharpening in here, I'll give it a go.
Looking to improve on my sharpening, currently have a couple of whetstones; a pretty coarse 2 sided one, (not sure of the grit) and a Suehiro (sp?) 1000/3000, but to be honest I've never been able to get an amazing result from them, think I just struggle to keep the angle consistent - mainly around the tip.
Wondering if it's worth getting a guided system, the options I've been considering are the lansky diamond system (plus the leather strop), or work sharp precision adjust (maybe the elite?)
Only problem is I've read quite a few 5hings about them not being so great for long kitchen knives; they are more targeted at the US EDC/hunting market?
Also noticed the work sharp electric knife & tool sharpener being mentioned a couple of times, which is around the same price as one of those manual systems? Would give a bit more flexibility in terms of what I can use it for, but how's the quality?
Most of my knives are relatively cheap & cheerful - not bottom of the barrel budget supermarket quality, but nothing special either, however I do have a nice damascus petty and a 10" sashimi which could do with a little more care.
I could just keep practicing with the whetstones, but to be honest the poor results are frustrating me and putting me off actually sharpening them at all
3 Mar 2010
Surrey
I might be causing chaos but Horl? I really don't want to get into faffing around guessing with whetstones.
6 Oct 2004
Birmingham
Is that the rolling one? Have seen mixed reviews of those (although probably down to people using cheap knock-offs, which is obviously going to be the case with any system).
Edit: also ridiculously expensive by the look of it, £150 for the "starter" with a single stone & hone, £50 for extra stones?!
3 May 2012
Wetherspoons
Just practice, a whetstone, well two, are all you need really.
I have three, they go from 600 - 6000/8000, but you only really need two.
On a decent knife that's only a bit dulled I'd start quite high maybe 3000 or more.
I'd only go down to 1000 for some dinged up cheap kitchen knife, and the 600 I only ever use to rub against other whetstones so they stay flat.
Get a leather strop as well.
My Japanese nikiri I've only had to sharpen twice, both times didn't take long at all, and just did it on 6000 to start, and even then not many passes either side, then strop and it was like a razor again.
The metal is hard so you are really only taking a tiny bit of material off, almost polishing the edges.
Cheap stainless steel kitchen knife is another story and often they do need to be worked a bit more.
3 Mar 2010
Surrey
I pulled the trigger and got a Horl 2 I had a demo in a shop local to me - amazing thing, sharpened all my knives in under 20mins, no regrets purchase. I don't really want to or have the time to learn another hobby, keeping it simple for 150 quid and a few minutes, I'm fine with.
6 Oct 2004
Birmingham
I picked up a cheap "Trend" 400/1000 diamond stone, and it's on a whole other level to my whetstones, only used it on the cheaper knives so far, but got a really nice edge on them, and use my 3000 grit stone to finish them off. Also grabbed a strop and some compound, and definitely an improvement! :)
Man of Honour
17 Oct 2002
Ottakring, Vienna.
Happy with these three for now. The Nakiri is GREAT for chopping veg, I use it a lot.
I've no idea how, but my wife has cut herself with the petty knife three times in a week. Her mother came to stay for a week and used it multiple times daily with no problems, and I've come nowhere near cutting myself so I think it's a skill gap!
I came home from work the other day to find my wife using the Nakiri like a cleaver to chop through the woody stems of some flowers.
So now it's a Nakiri with some nice chunks out of middle of the sharp edge.
20 Feb 2004
Hondon de las Nieves, Spain
Huge bump.
We’ve just unpacked our knives and after using some cheap ones in the rentals have realised how dull they are.
They’re nothing too exciting and I’ll be honest right now that I’m not going to get any stones etc and learn to do it myself.
Is there any “automatic tool” that’s better than others to not destroy knives? Worst case it sharpens them a few times before I’m left with no blade but at least that’s more than I’ve got now.
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Huge bump.
Look up rolling knife sharpener. The way it is design, it is at a right angle everytime.
There are lots of knock offs for less on Amazon.
28 Jun 2013
Huge bump.
get a DMT Aligner kit for £65
its not automatic but zero skill is needed really except some common sense and results are excellent and consistent in my experience
