A used RTX 3070 I think would be the best option for the OP.
I am the op, why are you avoiding the question
I just got a 4070s, the op was for a friend if you read it you would have seen thatSince you seem to be impressed by the RTX 4070, you could wait for the used prices to come down. For now, the prices are nowhere near £300.
The problem with 3070 is the the 8GB limitation is a very real issue.I cringe whenever I hear "fine wine", it's a load of ******** these days.
The 3070 is the best choice out that lot in my opinion, if only there weren't so many faulty 2000 series cards with space invaders issues then I'd have said 2080ti.
The AMD alternatives look weak in comparison, which they absolutely wouldn't at the higher end.
Sorry - was replying to this comment - but skipped a fewA used RTX 3070 I think would be the best option for the OP.
Age and tbf about £70 more used not doubleGiven it's roughly the same performance, and more than double the price, why would you go for the 3070 over the 2080ti?
This is not a bad point, but these weren't meant to be high end cards, more aimed at the mid sized wallet buyer...Even for 1080p the 3070 have to turn down graphic settings like texture sooner rather than later just so to avoid hitting the vram ceiling that would lead to stuttering.
That's a cracking price for a 3070 - would be a tough choice there*A used RTX 3070 + warranty can be had for ~£310
Yes the 3070 is a known mining GPU
Radeon RX 7600 XT Review: Can AMD Eliminate The RTX 4060?
Asus Redemption Link: https://www.asus.com/au/events/infoM/activity_4429Support us on Patreon: https://www.patreon.com/hardwareunboxedJoin us on Floatplane: ...www.youtube.com
I'd go for the low £300 4060 Ti cards currently selling on ebay atm tbh.
