- 7 Sep 2020
- Gods Country
Which way does the deck go if both sides have grooves?? Asking for a friend lol
You have to sand one side flatWhich way does the deck go if both sides have grooves?? Asking for a friend lol
Till it warms and shrinks, and discolours. And then ends up in landfill. And it gives off carinogens in heat.We swapped our wooden decking for composite, best thing we have done
4 years in and none of those problems so farTill it warms and shrinks, and discolours. And then ends up in landfill. And it gives off carinogens in heat.
Grooves up in this case as they act as a channel to run water away (erected with a gradual slope away from the house).
Yes and of course water only obeys mavity if it has some grooves to run down![]()
I am going to be THAT guy - your decking is on upside down.
Chaps,
I really need some "direct" green finger advice here! I have this idea of sorting out all of my beds (16m length). Today I made a crack at clearing out about 9 large buckets of ivy and lose junk on top. I am left with this:
I am desperately trying to save the hedge (left hand side) as I love the idea of someone planting it a tonne of years ago. It is a bit sparse at the bottom but since removing a lot of the ivy that was strangling it, it seems to be doing well at the top.
The area I cleared around the trees is wet --- it is mostly clay but there is a decent amount of top soil.
The bush on the right is a type of ivy too I am told, but it seems to be quite pleasant looking and self-contained.
Qs - What do I do with this space now?
1. Can I just bark all over the bare soil, and it'll be weed free?
2. Can I do something to save the hedge further? Feed it or something? It seems sturdy but it isn't thriving.
3. Is there a bush or something best suited to this shaded but moist area?
4. The turf ends in "moss". Do I just overseed?
Many thanks!
What do you use instead?I'll just say in my experience of barking, birds threw it all over the place and I was forever clearing it up. You'd also need a membrane and no it doesn't guarantee being weed free.
Haha check my other thread - I am building a 6x4m summer house and already have a 13m x 3m workshop. If I add one more out building I'm going to get shot![]()
The Hangover Corner Garden Bar III | Dunster House
Make your garden the place to be with The Hangover Corner Garden Bar III. Measuring at W2.4m x D2.4m, this bar can easily fit into that unused corner of your garden. Constructed using a DIY panel system for quick and easy install. The high-quality Hangover Corner Garden Bar III can be made in as...dunsterhouse.co.uk
I'm tempted to plant laurel or something and just hide the ground...
Now that's an ideaLooks brilliant - need to treat yourself to a nice BBQ now
