Agreed. Sort the thread title out
@Amatsubu
Done
The Rage Art / Special can be blocked if you aren't constantly attacking. I really struggle against constant attackers, something I need to work on.
A lot of people do, me included and even people much better than me can still lose to mindless pressing sometimes because there are a lot of knowledge checks so if you struggle with something, watch a replay and try out different solutions. Turning on framedata will also help as you'll see when they press at minus frames. The game will also automatically show you recommended punishes during a replay and you'll be able to test them on moves you left unpunished during match.
The replay feature is game changer and they completely smoked other fighting games with it when it comes to learning.
Everything that's at least -10 is a guaranteed punish and even if a move is safe but heavily minus, they lose their turn and shouldn't be pressing afterwards.
People throw out a lot of unsafe stuff so it's really important to make them pay for it.
Remember that a single jab is your best friend, fast, quick recovery, +1 on block and +8 on hit so try it out for interrupting and if you have a decently fast counter hit launcher you can try it to see if they press. At +8 they're basically at your mercy. You can hit low, you can hit mid, throw, whatever. They have to guess or mash their panic buttons but a lot of them won't work vs. fast options when they're so minus. They can't really step either unless you use a very slow move.
And this is a situation you can create with a single jab on hit
You have to show them they can't just mash in your face. Use df1 as a mid check as well if they start ducking too much.
You can even try a standard crouch jab of you're unsure as it'll often interrup mashers, commonly known as a **** jab
As for panic Rage Arts, you have to do staggered offense, some empty dashes into block etc.
A single jab again is a godsend because you can bait them into pressing RA but the recovery is so quick that you'll be able to block in time.
Hope this little essay helps
For now, just have fun and when you stagnate in ranks, that'll mean you've found your level and you'll see what to improve.
