- 6 Apr 2009
- Exeter, Uk
Hey all, I'm looking at putting together a new rig. Last time I asked you helped me put together an awesome piece of kit, just looking at when that was I can't believe it was 8 years ago! And to be honest it can still handle almost anything I thrown at it!
Although its definitely getting rough round the edges now and the water cooling system is making some strange noises.
I use it for UE4 games development so a lot of lighting builds, video editing, some heavy number crunching, as well as gaming and want to invest in a VR setup in the future.
I haven't been keeping up to date with the latest developments and kit for a while, but was thinking:
I'm not too sure what the price range would be to give me a pc in a similar performance bracket (relative to todays standards) as last time (see below).
But have a budget of around £1,400 (not including peripherals or OS) can go up or down depending.
First thoughts as a starting point:
If anyone could suggest a kick ass components list or some other pointers, would be really appreciated.
A couple questions:
What is the difference with Raptor Lake-S (rather than without the S)
From the little reading i've been doing the Alder/Raptor processors sounded pretty comparable and there wasn't a massive improvement in performance in the latest gen?
I haven't had time to do a detailed check on the Intel chip options, any better options in the price range?
Previous Spec (2016)
Motherboard: Gigabyte GA Z170 Sniper
CPU: Intel Core i7-6700K (8M Cache, up to 4.20 GHz)
GPU: Gainward GeForce GTX 760 Phantom (upgraded to 2047MB NVIDIA GeForce GTX 1060 6GB (Gigabyte))
Chipset: Intel Z170
RAM: Ninja-V DDR4 3000
SSD: Samsung 850 Evo 250GB
HDD: Western Digital Blue 1TB 7200rpm
£974
[https://forums.overclockers.co.uk/threads/new-pc-spec-check.18723999/#post-29317081]
Any help in specing me a new PC would be great..
Thanks,
Mach45
Ode to Old Nelly c2016-2024:
- i7 processor latest gen (Raptor/Alder) LGA1700
- As far as gfx cards go I'm completely out of the loop atm. I have a GeForce 1060 GTX 6GB which was in the best performance but still affordable bracket at the time so thinking a 4060 with 8GB+ would be about equivalent now?
- 32 GB of RAM, having done just a bit of reading some people were saying there isn't a massive improvement using DDR5 over DDR4 even though it goes up to 6600MHz? (in fact some people were saying they prefer to stick with DDR4), is this true?
- For storage 1TB SSD for OS and critical apps, and 2TB HDD for the bulk of apps, games, file storage. Also need a dual-layer Bluray writer.
- I love the water cooling in my current setup so would want to go with that again.
- Also looking for a funky clear sided full tower case with space for an optical drive, 2+ USB in front panel, and like to keep the cabling tidy so space to hide it away.
- https://www.overclockers.co.uk/inte...t-lga1700-processor-retail-pro-int-00801.html (£389.99) (K for OC and F as don't need integrated graphics)
- https://www.overclockers.co.uk/giga...-lga-1700-ddr4-atx-motherboard-mb-5bp-gi.html (£269.99) (always liked Gigabyte)
A couple questions:
Chipset: Intel Z170
£974
Thanks,
Mach45
