If you like the sofa style and comfort look at other suppliers as all pick different fabric options based on what they think works and sells well. It also worth finding out if your local stockist can accommodate. For instance on here there are 196 fabric options rather than say 10 a local stockist might do. https://www.relaxsofasandbeds.co.uk/products/details/alstons-fairmont-grand-sofa1.htmlBrilliant
Turns out there is a stockist 15 minutes away from me, I'm going to pop in and have a look. I quite like the Fairmont model but there are a few other nice ones. Fabric choices aren't the best but can always reupholster in the future
And a bit about fabrics from Alstons
Alstons - Sofas for Living
www.alstons.co.uk
