Carried over winter using the bargain priced Ellese stand bag I picked up in my local American Golf last year for £70. Used it on my trolley over the summer and carried it Dec/Jan or when on the par 3 course. The only niggle I have is my clubs, noteably driver, sometimes get stuck in the dividers (6 way). Other than that is seems to be holding up fine from a wear point of view, unlike my body which doesn't seem to enjoy carrying
(picked up a niggle in my right arm which coincides with when I started carrying in Dec).
I'll have to go take a look at AG
The Spalding is technically an AG one, got it 18 months ago ish but used it for ~6 months then got a cart bag over spring and now back to using it.
My current bags don't have the full dividers and I get a similar problem it seems, assuming I'm reading it right, both the ones I mentioned have full length dividers so potentially would avoid that issue... At a cost
Stand bags on a trolley can end up a bit "off" if that makes sense.
I have a large "pro" bag which I use 90% of the time on my trolley. I also have a titleist pencil bag for those 9 hole rounds during the summer etc. Saying that I've carried it with 14 clubs for 36 holes before and it was fine.
I'd always commit to either a stand bag and no trolley.... Or trolley bag all the time. If that makes sense!?
Yeah, I've used the stand bag on a trolley a bit and it seems to rotate itself about 90-degrees, also with buggies it can be a bit awkward with the lever for the legs as it doesn't really fit nicely. Would kinda hope the Ping Hoofer at least with it's passthrough bit being good for buggies at least, but dunno.
I do have a cart bag as well for trolley/buggy use, and it's likely I'll switch to buggies again over summer and only occasionally walk anyway, was originally thinking I'd make the Spalding bag last until April-ish when buggies are allowed back on the fairways and then leave replacing it till the end of the year but now it's annoying me a lot
But I get what you're saying, plan would likely to switch to cart bag over summer because of buggies and occasional trolley rounds and the stand bag would be gathering dust until winter...
I use a pretty entry level callaway x series bag. It's been solid for me. I carry in the winter when I have to park the trolley far away from the greens can only use it on the rough etc.. and then in spring onwards stick it on a Motocaddy Cube. No issues there. It seems rain proof as well. Nothing inside ever gets wet and fabric is easy to wipe clean.
It was under 100. In winter I only use max 8 clubs anyway so carrying isn't an issue.
I have to say I'm not particularly impressed with my Callaway cart bag tbh :/ Did look at some of the ones in the shop but nothing stood out...
Forgot to mention but waterproof-ness seems to factor low on my requirements, I usually don't play in the wet, he says with a round booked tomorrow with 'showers'
Pretty sure neither of my current bags are waterproof but never been a problem.
I do like playing a half-set tbh, did it a bit last winter but so far just taken the full set this winter so far, was good though, I should do that more
