I have a sneaky suspicion that Tapo and Eufy all originate from the same factory, I guess it comes down to which vendor has the best deal at the time of purchasing :)
Blowy blowy thing, very impressive, I shall no longer require canned air and it has a sexy braided cord, life goals..... :p
Nice Ann summers purchase!
I've had my X552 CompuCleaner for a couple of years now and it's very good.
A little tip for you. Don't try to blow the dust from your PC indoors. I underestimated the power of the CompuCleaner, thinking I could catch the dust with a hoover. How wrong I was. :o
I would be very careful how you use it anyway, OK for radiators and fans but blasting video cards may end up an expensive mistake. Personally I prefer to use a brush and vacuum cleaner, it might not be as effective but good enough and safer.
Treated myself to a ROG XG Mobile 3080 (tough to find!) for my Flow X13, just in time for a holiday (where I may end up playing Starfield etc). Impressed!
Another tubeless related buy, an Airshot (this shiz is expensive...)
Worked well in seating both tyres, just required a few extra pumps and they went up fine.
Ummm
I do also have one of these as well. But my bike was such a pain to go tubeless for in end I didn't use it!
Thanks, it's for my desk area mostly, it gets very dusty as it's next to the fire and also all the salt from the sea, as such hoovering it never seems to get it clean. After one quick blast with the compucleaner my desk is sparkling and my robovac thing is happily hoovering up the dust. I very definitely didn't think I'd be saying that in earnest 20 years ago :p
Does it actually work as well as the canned air?
Cheap little 3.5" screen off Ali Express for like £12 delivered
Cheap skin for my Ally Rog to see what I thought of skinning it - £6 delivered (yes I left the bezels showing, it was very weird with them covered with the pattern to my eyes.
How's the ally vs the steam deck if you've used both?
