Man of Honour
- 23 Mar 2011
- West Side
Most coolers come with paste but I can't see any listed so if building it's yourself it's best to get some , the Arctic mx4 is a good budget friendly tried and tested pasteI've submitted a ticket with OCUK and referenced this thread, so we'll see what they come back with. If they won't build it or the price is too high then I might go ahead and build it myself..
If that happens, I have a few questions
Does anyone know if the CPU cooler comes with thermal paste already applied or comes with a tube of paste that I need to apply myself?
I watched a few videos on builds and some of them that had Ryzen 5 mentioned about flashing the Bios? Is this something that needs to happen or will the above motherboard recognise the CPU etc. ?
Otherwise I don't think there's anything else I need to be aware of, I can see the SDD install different from back in the day and have a heat sink!
Thanks,
Phil
Arctic MX-4 Thermal Compound (4g)
Order Arctic MX-4 Thermal Compound (4g) now online and benefit from fast delivery.
You won't need to flash the bios as the 7600 is compatable out the box and will work but mite be wise to update the bios later for improvement made.
Nothing changed from the old days of building a pc same basic build , if anything it's got slightly easier with an m2 drive doing away with the cables of the old style SSD.
RGB can be a pain but that case it's all built in and the CPU cooler will be easy to sort.
There are loads of videos on YouTube to guide you threw a build .
The first boot on a new AM5 system can take up to 15 minutes to show on screen as the motherboard is training the memory so be patient and it may restart a few times.
