- 1 Jul 2003
- There's a voice that keeps on calling me.
Are you going via the Tunnel? If so you can charge at both ends while waiting for the train. The Tesla chargers are open to all, there are some other non-Tesla units on the French side too. Not sure if the U.K. side ones are active yet.
I usually top up to 90-100% in the dead time between check in and being called forward to the train. ABRP does t normally take that into account in my experience so any planned stops go immediately out the window.
If you have any charging problems, it will more likely be on the U.K. side. In my experience, a lot of public car parks on the continent also have AC chargers you can use. You’ll probably need an app of some kind to use them. Shell recharge, Octopus Electroverse and ChargePoint are good U.K. based roaming apps with plenty of options on the continent.
The reason why they ar cheap is because they only attract 2% BIK at the moment, ICE cars are considerably higher. It’s not really anything your company is doing there.
It’s worth noting that the 2% BIK won’t last once ICE cars are no longer available to buy at volume.
Up until 2/3 weeks ago all cars had a huge personal contribution (on top of the tax), now the EV's have that slashed. I can have a base MG4 and £50 a month back!
Noted on the roaming apps.
