Deleted User 298457
Deleted User 298457
No chance is a Leaf getting anywhere near 240. My e2008 probably gets ~200 MAX in summer and closer to 160 in winter with normal driving.
You'd get that range out of a Zoe but not sure if it would be too small. I did a 165 mile round trip at the weekend, mostly motorway and left the house with 96% battery and came back with 2% battery, once it warms up a 165 mile range would be easily done - did have the heater on and heated seats and steering wheel.Thanks very much. Sounds like it may well get left behind going forward. Most of my social driving would be covered by the range of the Leaf, but I do do around 5-6 journeys a year that are 165mi each way. The destination has a charger at the property so that's no big deal, assuming that's within the Leaf's range.
To answer your earlier post that I missed (sorry!), no real reason for the Leaf. Just that its quite readily available at my budget, appears to have a solid range, and reviews well. I'd have to test drive to see if I could live with the weight/handling. Are there other options to keep an eye open for? Jag i-Paces pop up for around £220 but then they're much older still, have reported reliability issues, and I imagine the insurance would be bonkers. Other than that everything seems to be super-mini segment size.
you literally just worked it out for yourself.Battery size x 3.5 is the realistic range for a EV when range actually matters ( sat on a motorway). No idea how a leaf is claiming 240 miles range ?
any yet peugeot claim 250 miles out of a 54kwh battery (the older E2008 is less, but on a 50kwh battery so it depends which you have i guess)No chance is a Leaf getting anywhere near 240. My e2008 probably gets ~200 MAX in summer and closer to 160 in winter with normal driving.
I would say it comes down to the efficiency of the EV. For a real world comparsion, I was spending about £100 per month on fuel, now on Kona get around 4 miles per kW and £60 per month, I pay around the same 36p/kW at Tesla supercharger, so around 40% less running cost. And more if you remove road tax. Not sure about mpg but my ICE car would get between 420-520 miles per 45 litres of fuel (ran to nearly empty 50 litre tank). That would last 3 weeks.Im toying with moving to an EV but might need a sanity check, and definitely need to do more research.
I currently have a petrol car with a value of around £4000, that does 48ish mpg. With my current commute (65mi per day, 60 of which is dual carriageway or motorway), I'm spending around £240 on petrol a month, including social mileage. I pay £180 in tax and service it 3x per annum for a total of around £350 (DIY job).
I've been looking at leasing a used Leaf e+ (the bigger battery variant), and can get a 3 year old one for around £210 if I chop my current car in as a deposit. I have free charging at work, which would probably cover most of the day to day stuff and a large portion of the social driving too. There's are no available EV tariffs in my area though, so charging at home would be around 36p/kW 2 years servicing would be covered in the lease. Does this actually make sense to others?
3.5 is a number I ‘made up’ motorway based on driving thousands of miles in many EVs and an optimistic number to be honest and would require 70mph. Who reall cares about range doing 15 miles commutes on B roads anyway when you are topping up. No one is doing WLTP cycles for 200miles. My point was simply look at battery size and multiply by 3.5 for motorway range. Ignore anything else about claimed range numbers.you literally just worked it out for yourself.
62kwh battery (59 usable) by your reckoning takes you to (almost) 210 miles........ but 1) 3.5 is a number you made up and isnt how the claimed range is worked out and 2) no range advertised is ever realistic, be it WLTP range or petrol MPG.........
but anything close to 200 miles is perfectly usable esp for a 2nd car where the other car is an ICE in this country.
my ipace is a massive slab of metal, great car, not the best EV... that has an 84kwh usable battery which claims.... 290miles i think. i have got 260 out of mine, driving fairly conservatively but not like a granny and that is a car which at the time was over 2.5 years old and 44000 miles on the clock so the battery may have lost a little capacity as well.
on a motorway run to my parents my record is 240 miles,
a leaf should do far far better per kwh.
i thought it was obvious.3.5 is a number I ‘made up’ motorway based on driving thousands of miles in many EVs and an optimistic number to be honest and would require 70mph. Who reall cares about range doing 15 miles commutes on B roads anyway when you are topping up. No one is doing WLTP cycles for 200miles. My point was simply look at battery size and multiply by 3.5 for motorway range. Ignore anything else about claimed range numbers.
Just didn’t understand the 240miles comment. Not sure why you have gone into a story about your ipace. Ipace is actually pretty decent at real motorway speeds. Even a Kia soul struggles to get over 3 if driven like a ICE would in a motorway.
Hence I shortcut all that by using 3.5 Tbh I didn’t know much about the big battery leafi thought it was obvious.
240 miles is WLTP range, which is an industry standard. yes it is (very) over optimistic if you pick the worst case scenario for range, but it is still way in excess of what the poster said he needed (165 miles of range).
i mentioned my ipace as an example because it gave a fair example of how far the WLTP range is off the actual real world (240 motorway in mild weather vs 290 WLTP).
if you have driven many EVs then you know exactly how it is claiming 240 miles. you name me a single car which can do WLTP range on motorway miles. EV database is great for these sorts of issues but sadly doesnt have the car in question on it.
i guess the point is........... we are sort of agreeing. Even using your benchmark the long range leaf should be capable of 200miles or close to it on an average motorway run, which is a very usable range, esp in the uk.Hence I shortcut all that by using 3.5 Tbh I didn’t know much about the big battery leaf
If you turn off the extension temporarily, then view the single car advert, turn the extension back on and refresh the page, it still works for me..Those original Ioniq's in big battery spec seem like cracking value.
As a side note this made me sad...
2% battery as well.............. they have bigger cahoonas than i have that is for sure. As soon as i get under 10% i start to get twitchy. I am no expert but isnt the remaining charge in car batteries a bit of a guess, and depends on how well balanced the battery is?A 50kw Zoe maybe, but in a ZE40 - only in summer if you stick to 50 the whole way!
Works fine on Firefox still.Pretty annoying!! And I only discovered it a month or so ago![]()
2% is not a lot of margin for error.
