You sort of touch on my point here. My issue with Canon is that for high(er) end use it only makes sense when you use their L glass and once you go there it’s darned expensive and there’s no going back. You can still of course use the older EF lenses with the adapter but they are heavy and clunky and I don’t miss them one bit from my Canon DSLR days. Furthermore, the higher end Fuji glass isn’t far behind those older lenses in terms of IQ.the lenses at the time, the 23/1.4 and 35/1.4, although decent (for hobby), they do not stack up against the Canon L glass. The 35L is leap and bounds better than the 23/1.4.
One of the things I like about Fuji is you can pretty much come in at any level (exceptions do apply) and have yourself a very good setup but there’s always scope to improve. With Canon I found their budget line (Full frame and APS-C) just bang average and not all that cheap on occasion. As i said, you have to get the L glass and the higher end bodies to really see what Canon are capable of - and at that point you’re into (very) roughly 3x the cost for a body + mid range and telephoto f2.8 zooms.
