- 21 Jul 2005
- Officially least sunny location -Ronskistats
Turning off Global Illumination & Ambient Occlusion fixed it for them, no crashes since. (7950XT irrc)
Engineering sample?
Not a bug, if you interrupt the reload before you’ve cocked the gun (by checking the map, stratagems or diving), then you’ll have to finish off the reload. Alternatively, if you still have at least one bullet in the gun when you reload, you’ll not need to **** the gun and just swap the magazine.I've had reload bugs, reload, press fire *click* "out of amo"
Was this against the robots? Possible your stratagems got scrambled if that’s the case. Not heard any reports of stratagems getting mixed up by bugs (you know what I meanOh yeah, anyone elses strategems playing up today? Just called in a rover but turned out it gave me an orbital strike on the entire squad, they saw the funny side though.
)Was this against the robots? Possible your stratagems got scrambled if that’s the case. Not heard any reports of stratagems getting mixed up by bugs (you know what I mean)
Yeah tends to not happen on nvidia cards as much so I’ve read.
Yeah against the Automatons, is this normal? First time its happened to me
Some robots have the ability to scramble your stratagems, it's a mechanic in the game![]()
I've seen my Strategems say 'blocked' and i can't select them but what was happening earlier was i would select and execute one startegem and then it would deliver another.
.To be clear as that thread references both, there's 2 different effects - there is a jammer tower which blocks strategems from being called in until it's destroyed which is when you see them being jammed and get a white noise effect when looking at the list, and there's a modifier which causes strategems to be scrambled - so you can still call them in but the input codes are mixed up.
It's a mechanic in the game, and it's bloody hilarious![]()
We were all laughing our arses off after the initial shock
I might not be as sensitive to it as others but disabling AA and turning sharpening off has made the image look significantly cleaner for me - but again, I'm not as sensitive to the AA issues that are often discussed.Solution to the awful aliasing issues in this game until they add DLSS.
Disable AA in game and if you have a nvidia gpu, apply FXAA via the CP, not perfect but it handles the shimmering slightly better than the in game AA and most importantly, objects/terrain in the distance looks far better/more detailed along with motion clarity being much cleaner.
If you have the grunt though i.e. 4080/4090, use DLDSR instead.
I find the AA in the ship environment is a lot more janky than general in game. In game, I don’t have any issues with picture quality or clarity.I might not be as sensitive to it as others but disabling AA and turning sharpening off has made the image look significantly cleaner for me - but again, I'm not as sensitive to the AA issues that are often discussed.
