Firstly, a little background.
Around 9 months ago I decided to upgrade to the following :-
www.overclockers.co.uk
Following the build I had issues with games crashing, BF2042 wouldnt play unless I slowed down the CPU, Forza H5 and Wolfenstein TNC would crash randomly.
Memtest revealed multiple errors so I spoke to OCCS and they recommended that the ram was too fast for the board and on their advice I downgraded to :-
I also later in the year changed the motherboard to this one I picked up from the MM :-
And added an extra:-
Due to a busy summer I didnt do much more gaming but when I did it seemed to be stable.
I recently started playing Sniper Elite 5 quite often and after a couple of months that also started to crash quite regularly.
I also noticed that other programs I use started behaving differently ( CCTV for eg would hang and not display camera feeds without restarting ) and I would get the occasional BSOD.
So I thought right, time for a fresh windows install and thats when I suspected something was really amiss.
It took 4-5 attempts before windows would install, with numerous BSOD during the process.
Some of the BSOD were that quick I didnt get chance to write them down but ones I did were Memory Management, System Services Exception, Page Fault in Non Paged Area.
Now I've managed to get windows to install it runs terribly, drivers wont install and just hang or BSOD, programs that do install hang or BSOD.
When the PC goes to sleep it wont wake up without rebooting.
So after a little research I have run the following tests :-
Memcheck86 - Took 15 hours and returned almost 4000 errors.
OCCT - CPU test for 1 Hour and returned 120,000 errors across most cores ( couldnt check which as it crashed on completion )
LinpackExtreme - fails in under a minute.
What I have noticed whilst running these tests is that the CPU immediately goes to 100degC as soon as the test starts, it doesnt gradually build up, but is there within a couple of seconds.
Other hardware is a Dark Rock Pro 4 cooler, Superflower 1000W PSU and a Gigabyte 3080TI.
So apologies for the long post but I knew you would want to know most of this before commenting.
Is there anything else I need to be checking or should I just be contacting OC ?
Thanks in advance
Intel Core i9-13900K (Raptor Lake) Socket LGA1700 Processor - Retail
Order Intel Core i9-13900K (Raptor Lake) Socket LGA1700 Processor - Retail now online and benefit from fast delivery.
Gigabyte Z790 Gaming X AX (LGA 1700) DDR5 ATX Motherboard
Order Gigabyte Z790 Gaming X AX (LGA 1700) DDR5 ATX Motherboard now online and benefit from fast delivery.
TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-60800C36 7600MHz Dual Channel Kit - Black (FF3D532G7600HC36DDC01)
Order TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-60800C36 7600MHz Dual Channel Kit - Black (FF3D532G7600HC36DDC01) now online and benefit from fast delivery.
TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit - Black (FF3D532G6000HC30DC01)
Order TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit - Black (FF3D532G6000HC30DC01) now online and benefit from fast delivery.
Asus ROG Strix Z790-F Gaming WIFI II (LGA 1700) DDR5 ATX Motherboard
Order Asus ROG Strix Z790-F Gaming WIFI II (LGA 1700) DDR5 ATX Motherboard now online and benefit from fast delivery.
Thanks in advance
SAVE 17%
£579
(incl. VAT)
£480
(incl. VAT)
£130
(incl. VAT)
SAVE 21%
£140
(incl. VAT)
£110
(incl. VAT)
