PC keeps shutting down after new CPU
1 Mar 2024
Leeds
My PC keeps shutting down after a new CPU. just black screen in the middle of games, it's fine when not gaming.
upgraded from a 3600 to a 5700x3d didn't chance any other parts, i had to update bios.
is it likely to be a faulty CPU?
Did you update chipset drivers 'n such?
Did it clear the cmos after the update?
If it did, have you checked your XMP & dram voltage?
Hi guy's, i have an NZXT 280 AIO so temps are good at about 60c
i didn't update any drivers i will try that, i did reset bios because it was booting was the fans stuck at 100% and i was told to reset bios.
i did set XMP after the bios reset i have 32gb of 3200mhz ram so just assumed that would work fine.
i will find the model info if needed
edit im drunk and didnt properly read this, delete please :(
If it was a bad CPU, I wouldn't expect BF2042 to work. Have you got any other games you can test?
I'd start by resetting everything in the bios and strip your build back to the minimum. 1 stick of ram (go with stock clocks, not XMP), boot drive and GPU.
Have you got another PSU you can try?
just low power games but thats the ones that keep blacking screening,
fortnight, sims and stuff like that all black screen.
bios is reset, i will test with one set of ram. i only have one PSU but can buy one to test if you think that could be it
Any overclocking on the GPU? If you've got afterburner installed, are you sure it's not applying a profile? I had issues with an unstable OC on Mass Effect 4's loading screen, of all places.
Had a 3800x briefly that did similar apex legends would crash after five minutes, was perfectly stable in all the usual stress tests and other games. I could use ryzen master to set fixed clock speeds before playing apex legends to stop it, returned it wasn't happy with a faulty processor.
i think the PSU is faulty, id got a friend to nip round with his 850w and its all good.
do you think 750 is enough for the system, or could the problem the PSU was not strong enough?
i do have an oc that's been stable for a long time, but i will test without it now as i didnt think to be so.
6950xt on a 750w Psu is cutting it fine imo due to power spikes, 850w minimum but a1000w gives you comfort.
I would lean more towards a dodgy PSU rather than 750W being too little. The OCP/OPP would likely be set 25-30% above that anyway so if working properly it should easily handle the spikes of a RX 69**XT.
It was awhile ago, but I seem to recall people had a lot of problems with their PSUs with these cards, sometimes even going as high as 1000 before there weren't any problems.
sorry guys as said, i fitted my buddy's 850w PSU and all was good. so i ordered and fitted a 850w RMx and ive not had a problem since
