You anre over thinking this, there are few downsides to Intelligent.
You always get the 6 hour window, plus any others if they decide to charge the car outside this window.
The downside are if you have home batteries, because you can get cheap slots outside the usual fixed time. You need to work out a way to stop the car rinsing the batteries outside the usual scheduled slots.
Sometimes people get the odd failure, personally I’ve never had it fail but you can mitigate this if you are using the Tesla integration which you will be. Basically just set a schedule in the car to start charging at 11.30 and the car will always start. IO will override the schedule as needed, if it fails, it will just charge at 11.30. You’ll get 6 hours and that’s enough to add 56% charge to a long range Tesla. Unless the car is below 24% when you plug it in, you’ll hit 80% before the 6 hours is up so there is little risk of using peak time power.
Welcome to my brain...
Thanks for the reply. Our Model 3 is a ~50kWh SR+ so should be fine setting a schedule of 11:30 start and a limit of 80% as it will do that quite easily in the window - have no real issue in the 4 hour Go window to be fair (MG4 with its bigger battery and seemingly slower charge rate - per HV not comparing cars, is sometimes a little short - would be fixed by OI though.
We are planning on Solar and Batteries (latter first if cost doesn't work with our budget) when we come to renovate the house in the near future. Will need to factor in the car & trying to charge from the batteries. From memory on the HV you have to set it to charge from Solar manually anyway (Eco setting IIRC) so that should be fine so its just understanding how the batteries fit into the equation. Wouldn't a standard schedule set in the car prevent this for the most part (or does the cheap slot overrides cause the issue?).
I am struggling to think when I would need to charge the cars outside of the overnight window based on our usage profile so maybe not an issue in the grand scheme of things (unless I have mis-understood)?
