Yes, no SQM or anything enabled on my router, I've not seen the point yet.Cracking result assuming no SQM already running, and symmetric too! Thanks for the results, they're very interesting.
Who's that with?
Yeah, I saw that after I posted but tbh I didn't think anyone would care about the update. Serves me right for assuming! It seems a solid little unit tbf, especially now they fixed/added the IPv6 ACL, stateful firewall (I still can't believe they released it without one!) and QoS. The throughput (I'm assuming the specs are based on ~1500 byte packets) is phenomenal for the pricepoint, including multi-gig IPSEC/WireGuard/OpenConnect. I've run FOSS routers for *years* now, but this is really tempting me to the point I'm pretty sure I'll also have an ER8411 shaped box arriving next week.I do like a small ISP that actually provides the S in ISP
Just noticed this thread, ironically I have been looking at the ER8411 as an alternative to a UDM Pro or SE for similar reasons (simple life, fewer moving parts). I’m currently doing unspeakable things to shift packets (proxmox + OPN on virtual interfaces to pre-tag WAN VLAN, with a physical HA that’s not deployed yet, so you can imagine how much fun that is if I have to update the hypervisor), and just wanted a cleaner solution. I believe TPLink have addressed the IPv6 ACL issue according to the latest firmware release notes On paper, the numbers are impressive, and unlike Ubiquiti, TPLink seem to be open to feedback and if they can replicate the issue will deal with it, where as Ubiquiti have threads on the forums from 3 years ago about poor VPN performance with staff tagged that have just been ignored despite regular bumps/tags.
I’m going to have a play round with *wrt and perhaps OPN bare metal again, my ISP is DHCP but uses VLAN tagging on WAN, it’s simple enough to get OpenWRT/OPNSense to play nice, but both did some dummy spitting and required manually disabling and re-enabling the interfaces to restore connectivity and thats not going to work for me. Pre-tagging via proxmox virtual interfaces seemed like a simpler way to just present a clean DHCP interface to <insert distro here> and skip driver support issues on 2.5/10Gb NIC’s, but brings with it additional issues. I have almost resigned myself to an ER8411 sized box arriving next week.
You sign up now for instance £18 a month for 6 months then £36 a month after. Over 12 months equivalent to £27 a month.
After the 12 months can you sign up for another 12 months and get a deal again or are you stuck paying £36 a month.
I messaged them and they said at year 3 they apply a loyalty reduction equivalent to the new contract price. But when i asked for details of that they have just ignored me. So much for there great service if they just ignore you when you ask something they don't want to answer.As far as I know you are stuck at £36. Deals are one off.
I was with Aquiss for a year and they were brilliant, but too expensive. BT gave me an offer of £20 a month for the same speed, so I joined them instead.
Not as good and you cannot use your own router.What is the BT service like? Can you use your own router with BT?
Of course you can im using a Unifi Dream Machine SE.Not as good and you cannot use your own router.
I learn something new everyday.You absolutely can use your own router on BT.
line looks really solid.
@zia stick some SQM/QoS on the upstream and you'll be golden.
You can send them a letter and then just wait, saves the hassle. Otherwise, I found web chat painless enough (once I got past the 'What can we offer you?' script) - took about 20 mins. If you're using OpenWrt enable SQM, set the speed to 0 on downstream and 100000 on upstream, choose cake and piece of cake, link adaptation Ethernet, overhead 44 mpu 84. See how you go. If it's anything else (i.e. fq_codel) try setting an upstream shaper only at 100000 but you may need to tweak down to 95000 or so. Post your results!Will swap over to optiplex and have a play
Just spent over hr trying to cancel virgin media.....God i hate them
Zia
