- 28 Mar 2022
- ireland
Having good fun here with Bulletstorm VR on the Quest 2, doing it on the easy mode as I am not a great gamer, fun game if you like the Zombie shoot them up kind of thing.
You can use a referral for it, so make sure you do. There's a few steps to it, but you can get £23 store credit, as can whoever refers you.I should be getting a Quest 3 next week and it will replace my Quest 2.
I’ll mainly use it for sim racing so will use it tethered over USB while sat in a chair.
I’m guessing it’s just plug and play replacement for the Quest 2? I never really did anything for that to set it up other than download the Oculus software, but is there any software / advice for getting the most from the Quest 3? Any accessories worth getting?
Don't think you can get a referral for an existing meta account, needs to be a new oneYou can use a referral for it, so make sure you do. There's a few steps to it, but you can get £23 store credit, as can whoever refers you.
Otherwise it's more of less plug and play replacement.
Some sort of headstrap replacement/insert will be useful, and I'm waiting on the vrcover facial interface.
"Note: The friend you refer must be a new Meta Quest user and must create a new account in order to receive the credit."You just need a new device and to do it right. I've guided people here on how to do it before and it worked.
As he already has a quest 2 he won't be a new user and will have an existing account?
Thanks guys. I had forgot about the referral thing. I got the unit through work, so we have a pool of referrals that I'll need to use. I've removed the Quest 2 from my Oculus account, so we'll see how it goes.
I would like to buy these but I couldnt find where you put your prescription in. I could only see buy and didnt want to do that until I had input my prescriptionSpotted these prescription lenses on Aliexpress via a Reddit thread https://www.aliexpress.us/item/1005...ain.11.678118024mrvEf&gatewayAdapt=4itemAdapt they're mega cheap and the OP says they're ok. At prices like that surely worth a punt? If I'd not paid about 7 times the price for my Zenni lenses I'd chance it.
I don't know either sorry, i've not ordered them, but some people on reddit have so there must be a way. unless you have to contact the seller directly? not sure tbh.I would like to buy these but I couldnt find where you put your prescription in. I could only see buy and didnt want to do that until I had input my prescription
Looks like you have to contact the seller as one of the images of the product asks you to offer the data.I would like to buy these but I couldnt find where you put your prescription in. I could only see buy and didnt want to do that until I had input my prescription
