- 30 Nov 2011
As I said to Ray above, I'm no longer on "keto", I don't aim to be in ketosis or extend through diet on a daily basis, I'm eating plenty of meat to make sure I get enough protein to support my exercise/muscle gaining aims. Lots of people find carnivore through keto, but they aren't necessarily the same, though obviously you can use carnivore to lose weight, you don't have to, I prefer to fast for fat loss and optimise diet for long term health.Indeed, that point was tangental. I appreciate your info and you've help me understand something that I couldn't see the logic in. I hadn't actually consider the notion or benefits of the body being inefficient in dealing with certain forms of calories.
So question regarding long term keto type diet. Assume that at some point, people get to a normal weight, having been overweight. Do you see yourself on this diet from now on (albeit it adjusting somewhat as you see fit ?). If so is there some conversation to be had that once you are at a "good" weight, whether it is still best for you to be on a diet that requires your body to work that bitr harder processing food on an ongoing basis, i.e. digestive system and hence heart and respiration must be elevated when processing protein heavy diet. Over a day, I wonder what % "harder" we are talking about, raise heartrate by a few percent..more...less ?, is there any data on that that your seen ? I'm 60 yr old, so once you get to a certain age there are various other factors to possibly dial in.
Fasting also promotes many positive effects in its own right and I actually enjoy doing it so yeah both carnivore and fasting will be a long-term thing, it's not a weight loss diet, it's a lifestyle choice that prevents me falling back in to bad habits.
It isn't "working harder", it's purely a chemical process in your blood because your body has no way of storing excess protein, so whatever it can't use for muscle protein synthesis is converted to glucose, it has no effect on your digestive system which is self regulating. When protein is used directly for muscle they assign a certain calorific value to that process, when it's converted to glucose and then fat, 1g of protein produces less fat than 1g of carbs, even though they assign 4 calories to each on food charts.
Calories and the way they are calculated are so general that they only really "work" as intended in a very general "normal diet" type situation, there are so many confounders that you can make them look broken as soon as you step away from the "average" diet.
I wear a Fitbit and my resting and AVG heart rate has dropped since I went carnivore.
