Can you answer the question rather than deflect ?I can see how you get to 26k posts now.
I've been reading the posts and it's pretty damn obvious, playing dumb isn't a good lookCan you answer the question rather than deflect ?
The 3kwh is a hypothetical figure to highlight the significance of it's proportional imact of energy use to heat a car, in comparison to differing battery capacities. 15% / 2% are figures from my current observations. Perhaps that's a bit inflated - 13% / 3% might be more likely in direct same for same conditions.Can you answer the question rather than deflect ?
Not quite, I expect between 5-6 times. But, it may be that high when it's very cold.By your logic a Q8 has a battery 7.5 times the size of a leaf.
Oh you said bigger batteries aren’t impacted by heating as much. Glad we agree then
Perhaps you need to explain your actual point it in a less confusing way.I’m labouring this as your bigger battery is less impacted is so wrong. It makes no difference to the lost kWh and therefore miles only % drop. You are confusing the and not sure why you don’t understand what I am saying.
'Going on'? That was entirely what my original posts was about. If it's that obvious why are you continually 'going on' and questioning it?And why are you going on about warming up. Obviously we then have the effect of a 1 mile trip versus a 200 mile trip.
Playing dumb? Maybe I'd rather not spend all day arguing on the internet.I've been reading the posts and it's pretty damn obvious, playing dumb isn't a good look
There is no arguing. Just trying to help your understanding of physics.Playing dumb? Maybe I'd rather not spend all day arguing on the internet.
I'm not sure where the confusion is coming from? If a car takes w watts to heat and over the course of t time that drops the range by m miles then it doesn't matter if your battery is 10kWh or 1000kWh, both vehicles have suffered the same drop of m miles. Because the same amount of energy (e) has been used.Perhaps you need to explain your actual point it in a less confusing way.
What I'm confused with is why it's being framed like I've ever disagreed with these over-simplified calculations.I'm not sure where the confusion is coming from? If a car takes w watts to heat and over the course of t time that drops the range by m miles then it doesn't matter if your battery is 10kWh or 1000kWh, both vehicles have suffered the same drop of m miles. Because the same amount of energy (e) has been used.
or w * t = e
e / efficiency (m/Wh) = m
The battery size isn't part of the equation.
Exactly!To be honest, I thought the original point was a more simplistic "If you have a bigger battery/longer range, then you're less bothered if you lose say 15 miles of range to heating requirements, as it's proportionally much less of your overall capacity/range" which I don't think is a particularly controversial viewpoint![]()
Not you lol the other guyPlaying dumb? Maybe I'd rather not spend all day arguing on the internet.
Hardly playing dumb. Just depends on your use case in your heat. On 200mile trip the preheating of the cabin makes no difference if I get there or not without charging (0.5kwh by my maths) Having the heating on 21 or 16 does though. 3 hours of the car just losing the energy you have taken from the battery at around 1.2kW for 3 hours )(3.6kwh In this case the size of the battery is more important anywayNot you lol the other guy
But that's assuming you do exactly the same trip in a vehicle with a 30kWh battery vs a 80kWh battery.To be honest, I thought the original point was a more simplistic "If you have a bigger battery/longer range, then you're less bothered if you lose say 15 miles of range to heating requirements, as it's proportionally much less of your overall capacity/range" which I don't think is a particularly controversial viewpoint![]()
Zerohow much energy is being used to heat the battery itself, compared to cabin, if you are setting out with a ungaraged car on a 10C morning
(is the battery the main player - and it's heat capacity presumably proportional to capacity.)
Most cars won't be heating the battery at 10C. Hell, my Kona wouldn't warm the battery unless it got below -5C.how much energy is being used to heat the battery itself, compared to cabin, if you are setting out with a ungaraged car on a 10C morning
Maybe my brain is wired back to front but it still seems equally important to me. It's like saying, well it doesn't matter that my car does 20mpg, it's got a big fuel tank.It's not assuming that, it's not assuming anything about any specific circumstances or trips or charging regimes or use cases, it's making a simple generalised point that a larger battery gives you less of a usability impact if you have to spend energy on heating a car and (given the context of the discussion starting with heat pumps) that it's probably less of a worry whether your 100kWh car has a heat pump compared to your 30kWh car.
It may be the case that a specific use case means this is of absolutely zero consequence whatsoever to a particular individual, or it may not, I don't think that was ever really part of @Bug One's original comment.
