Somewhere I have a usb software
Typically I forget the name of it
But years ago I was messing around with bit flipping
On a flash drive (trying to make it appear as a fixed drive)
Was 128gb which wasn't exactly cheap back then
Anyway I made the thing totally unusable
Tried a load of softwares until finally
I found one that fixed it
Once I have the pc on will try to see if I stored it somewhere
It may well be as its hardware encryption
That as said there's a chip involved
And you can't do anything
But it was cheap anyway sometimes you win
Sometimes you lose
Edit
Name just popped into my brain
JetFlash Online Recovery is a repair tool specifically developed for Transcend JetFlash USB flash drives. In an attempt to repair your flash drive when it is no longer recognized by PCs or not working properly, the JetFlash Online Recovery provides the initial help by restoring your flash drive...
www.transcend-info.com
Second edit
The drive I fixed with this wasnt a transcend one
But it fixed it anyway
