And I guess these are yours @Journey
Just gonna throw em in my test rig and see what they do before prodding them.Oooh, Royal Fail didn't fail for once.![]()
ok so both boot, and both have vram corruptionOooh, Royal Fail didn't fail for once.![]()
Thank you for the updates mate
ok so both boot, and both have vram corruptionI wonder if we can make one good out of 2 or we swap all their ram...
Yeah one of them gets very, very hot so not sure if it is actually VRAM, think it is the larger one, untouchably hot.
EDIT: Also not sure how much VRAM costs these days, let me know.![]()
Its got 4 chips that are seriously burnt / have holes in the same place....
Yeah, that's got to be a power delivery issue somewhere?
I think last time I bought some of the Micron IC's they were MT61K256M32JE-14:A but those look like SK Hynix ones, I paid about $7 each from Aliexpress that was a while ago though, you probably have better more up to date info.![]()
Ive found them and 4 of them are 32 quid. I dont think the cards got delivery issue I recon somebody has clocked the nuts out of the memory for extended time... I wonder if it was a mining card?
Id probably replace them all looking at it tbh thats like 47 quid
Why it IC part number please? Can't see from that picture.![]()
H56G32CS40-X005
but looks like that is interchangeable with H56G32CS4D-X005
Got to weigh up the options then, if it is only the Memory IC's and the rest of the card is fine then maybe just order them as cheap as possible form Taobao/Aliexpress or something, and wait for delivery. How many hours is it going to take you to replace 6x memory IC's, and retest the card, as I need to make sure you are adequately compensated.![]()
Thought I would check the other one... different mem chips on that one
On this other card I'm just going to re-ball this ram IC real quick. All the other ics looked good underneath apart from this one.. who knows we might get lucky.
looking for stencilWow, you are on it like a car bonnet. *Eagerly awaits the feedback*![]()
looking for stencilcan never find what I need around here
and i dont have the right stencil... ok order that in then.
