- 22 Feb 2014
yeh jigsaws aren't really designed to do this kind of work.
Yeah looks fine. Cls can be brought back into shape too, so tack it all at the top then work down.
Just look down the length of the CLS you have to understand where it is bowed already; gives you a headstart.Yeah, I'll square up a laser line to the back wall and then set it all level to that, with the new protruding distance being set to the minimum required amount.
The Magnusson spirit levels are OK but for more accurate work I'd like a bigger bubble. I guess it's not surprising, cheaper tools not being quite as good.
Or pickup the titan thing for 50 quid.
Get a decent level, my cheap screwfix one nearly caused a fight with the builder for my bathroom lol.
If it's the titan mitre saw, the cheapest one is garbage. I returned it and bought an evolution R210 SMS.Is it going to be any good for £50? I read people having issues with the ones that cost £200. Plus it's going to be a pain to store, due to size.
One thing I might do is buy a sander so I can get the noggins to fight snug.
It is perfect for cutting CLS down and small enough to move right by the job, versus the Evolution (which I also have).If it's the titan mitre saw, the cheapest one is garbage. I returned it and bought an evolution R210 SMS.
Good shout.Just use a screw in the nogging near the end and use a hammer to pull the noggins level as if youre trying to remove the screw. Once it’s level fire a couple of nails screws in to hold it in place.
Then remove the screw from the noggin.
The evolution mitres from screwfix are good for the money. Get one and you’ll be sorted for the future too.
