Get a DP cable and you'll find you should have the gsync optionHDMI
I see. Monitor is HDMI connected, gsync setup should be near audio setup in this pic from what i learned.I'm not saying that it is that, just that CS2 (and CSGo) before that have been well known for stuttering issues.
Your monitor should have AMD Freesync, which NVIDIA settings should still detect as GSync basic or something similar (can't remember the terminology), but as @H2S04 has said depends how your monitor is connected HDMI or DP?
Yes minecraft is dependent on single core performance, but it's java based and there are all kinds of random oddities with it.
The RAM is rubbish then - it's just generic ram chips, CL22! and explains why it doesn't manufacturer or SPD details in your screenshots
Certainly won't help, while you obviously can't run faster than 2666mhz with that chipset, the latency is rubbish.Could the RAM be the problem then? I m running benchmarks now i update later
I don't want any overlay videosSo would you want a PUBG or other game overlay video?
*3D Mark Timespy Results:Yes.
1. It is not clear exactly what is happening and where/what the problem is, e.g. IS what you're experiencing just normal for your hardware? OR, is there is an actual issue that needs fixing.
and
2. IF the CPU is the problem, there's also this:
In other words: you're going to be bottlenecked if you upgrade the GPU, or bottlenecked if you upgrade the CPU and I don't have enough information from the benchmarks available to me, to reliably predict which upgrade is the best one.
I'd suggest you take the troubleshooting route being suggested above, so that we can identify if there is an actual problem, or if your hardware is performing normally.
Free benchmarks like 3D Mark Timespy and Cinebench will give you a comparable score and that's also helpful in identifying if your PC is working fine, or not.
i get itCertainly won't help, while you obviously can't run faster than 2666mhz with that chipset, the latency is rubbish.
But you are better looking at synthetic benchmarks like 3dmark suggest above to check your hardware is in the ballpark of other people.
Then try some single player games to see if they experience stuttering (to rule out network latency etc).
could PUBG practice mode do the trick? Good: your CPU is maintaining the advertised boost clock.*3D Mark Timespy Results:
- Summary: https://ibb.co/KKSWNGj
Good: multi score looks alright.*Cinebench Results:
- Summary: https://ibb.co/n77bR61
- GPU Rank: https://ibb.co/RBxFBDw
- CPU multi core Rank: https://ibb.co/9svwDVB + TEMPS after 9/10 min
- CPU single core Rank: https://ibb.co/3vRCpQk
Yeah if i upgrade the board thats the idea, i might even switch to AMD config with or without 3060 according to the benchmark results. The 11 gen was only if i could change the minimum and get 144 fps stability but now it sounds improbable.if you're going to upgrade board, cpu and ram. forget the 11th gen intel..it's old...also if you look at chart above, 11600 isn't that much more than a 10600..same cpu, just overclocked really....look at the the bottleneck it's causing with the 4090....you're getting 246fps, 1% low 157 and 0.1% 118, so you'll still get stutters...now compare that to the 7600, really bottom of stack for amd current gen...375fps, 224 1% and 185 for 0.1%
sorry, just reread and seen mobo not included, but just not convinced dropping 300euro is worth itat this point if this is your game of choice...upgrade your gpu again, and you'll be back in the same boat with the 11600....
So then its just rubbish ram and bad CPU cooler that cause these lags? Some internal CPU throttling?Good: your CPU is maintaining the advertised boost clock.
Good: your graphics card is maintaining the core/memory clocks.
Good: your graphics score is (more or less) correct for a 3060 8GB.
Good: single core looks alright.
Bad: CPU very hot, but this is common for Cinebench multicore.
Cinebench multicore is abnormally high load, so some throttling is fine if you have simple cooling.Some internal CPU throttling?
The impact of memory speed depends on:just rubbish ram
Personally think it's probably just normal behaviour for cs2, and that turning on GSync may mask it enough for you to not notice.So then its just rubbish ram and bad CPU cooler that cause these lags? Some internal CPU throttling?
Still no lead problem subject?
Yes, i found the adapter name: realtek 8821CE wireless LAN 802.11ac PCI-E NIC. Dont know if thats a cause in itself but i noticed these lags even when ping was fine.Are you using WiFi by any chance?
Tomorrow i receive VESA certified DP cable and test with gsync on to see if there is any change
i dont have the box in my room, its next door. Are you implying wifi multiplayer gaming = stutters and lags?Add a cat 5 cable to that.
It can be, hence why testing some single player offline games would be a good idea. (To rule out any lag based issues you are noticing, or whether it's just a cs2 issue)i dont have the box in my room, its next door. Are you implying wifi multiplayer gaming = stutters and lags?
i m on it, but today the router is bugging i m on phone hot spot. I planned on downloading War Thunder, Destiny 2 or COD Warzone i thought those would be real enough gamesIt can be, hence why testing some single player offline games would be a good idea. (To rule out any lag based issues you are noticing, or whether it's just a cs2 issue)
Wifi stutter/lag is usually more something you notice, e.g. you fire at someone and they're not there, because they reappear 5 metres to the left.i dont have the box in my room, its next door. Are you implying wifi multiplayer gaming = stutters and lags?
then i think i can make the difference. I also learned about the therms input lag, screen tearing, surely there are more i'm not sure i m precise with the ones i used but i think you got it in how you define performance stutter/lagWifi stutter/lag is usually more something you notice, e.g. you fire at someone and they're not there, because they reappear 5 metres to the left.
Whereas, performance stutter/lag is something you can feel, because it feels choppy and not smooth, the response to your mouse/keyboard movement is poor and the frame rate drops.
There are engines that mix the two, but that's the typical distinction.
you want me to make a hole through the wall for ethernet or are you trolling?Very much so. Maybe add a drill bit, pin hammer and box of clips to the list.
