- 23 May 2006
I am happy to test when they arrive ..... (just not on my carDo those hammers even work on double laminated glass?
No.Do those hammers even work on double laminated glass?
I think I've got the same ones, bought 2 for my car and 2 for the girlfriend. One is in the door holder and the other is in the glovebox but might move to the centre console. You don't want it flying around the car if you roll as you'll not find it!well if nothing else comes from this thread.... thinking of this just made me order these.... one for my car, one for the mrs.
I can't get the headrest off even when I'm calm without a struggle let alone in an emergency.Take the head rest off and jam the metal prongs in between the glass window and metal door. Pull the head rest down and the window will shatter. Very easy to say, but I can't imagine the sheer panic if you end up in sinking!
your link doesn't say it won't work does it?
It does if you read it.your link doesn't say it won't work does it?
How many charge cycles are some of these batteries rated for and are there many figures around showing battery health on older batteries?
I may have read it wrong but I wasn't sure that was the kind of hammer it was referring to.It does if you read it.
Can You Break Laminated Glass With Hammer.
"It is not possible to use an emergency escape hammer to break laminated glass"
Thousands and yes.
Let me just say most modern EVs will still have about 85% SOH on their battery in 200,000 miles or 10 years. EV battery warranties cover 70% SOH up to 8 years or 100,000 - 150,000 miles and they tend to err on the side of caution to keep manufacturers from having to shell out a fortune.
i don't know the charging history of my ipace. it had 42.5k miles on it when I bought it (still on factory tyres as far as I can tell somewhat dispelling the idea they wreck tyres). now it's on 48kish (tyres are ready for replacement in the next few months, more for the fact they feel quite old/ brittle and crumbling a tiny bit on the tread rather than bald)...... and still the range on the car is within what a Google shows it was when it was new. if I had to bet hard cash I would say it's still within worst case 5 percent of the range it was when new - and that is me being really pessimistic (ie within a margin of error of any range test i could do)How many charge cycles are some of these batteries rated for and are there many figures around showing battery health on older batteries?
