- 29 Jul 2013
Sage Precision Brewer might be more your thing?That Delongi looks good - it takes a mug and the steam wand will be good if the mrs wants a capo or a hot chocolate.
I'll see if I can find out more and see if it will do a mug of water. The French coffees are smaller typically and I'm using a small mug (not a bucket). It also does capsules so that can be an option for quick backup and no beans around. It also seems you can programme the cup volume. This could make it easy - with the two cup basically doing a mug and the one cup doing an espresso. Heat up time is 30 seconds.. which is acceptable, so by the time you've sorted coffee, cup and water.. it's warmed up.
