Those playing forbidden west may want to use RTX HDR as seems this game is broken with its native hdr too
Will be on it tonight!
Do I leave in game HDR on and Auto HDR off or both off?
Both off.Will be on it tonight!
What would be really impressive is if using AI they can get HDR running on a non HDR monitor.
Time for you to upgrade your monitor mate. You have a nice system there, but missing out if no OLED monitor.
As I have never seen what I am missing out on, I am currently happy with my current monitor.
I think when the time comes for the next upgrade it might be time to go 4k, then I'll entertain the idea of a new monitor.
It's not about the money, it's just that at the moment current monitor is fine.
Its relatively old that's true but its 1440p Gsync so currently doing a satisfactory job.
The majority of the Gsync ultimate monitors on this list seem unavailable to buy from anywhere when I check on the internet.
Also right now I am happy being able to max games at 1440p.
If I upgrade to 3440x1440 wont the 4080 struggle a bit?
I would have gone for the 4090 if I knew I was going to be at a high resolution.
Unless you hate DLSS then no. You should be fine. I would go for the new Alienware QD-OLED 4K monitor. Stick it on DLSS Performance which is essentially 1080p then in terms of performance needed. Or go Quality and it is 1440p.
Trust me. You may not know what you are missing. But I can tell you now. You are missing...
Which is the new one?
To be fair, I can just about justify £1000 on the Alienware AW3423DW, but anything more makes me feel bad.
The Aw3225qf. That is what I am going to get later this year![]()
But it doesn't seem as good as your current monitor.
It says its Gsync compatible, whilst your current is Gsync ultimate.
There is more to a monitor than it's G-Sync module though dude![]()
I now squat diddly about monitors as I never pay nay attention to them
The one I have is great. But if like me you want 4K then you will want the Aw3225qf.
Will the PS5 also work with this monitor? (Not that I have or plan to get one but it has been a thought in the past)
