- 19 Oct 2002
- Shakespeare’s County
I don’t plan to crash, nor change lamps. And if I do that what’s insurance is for. Meanwhile enjoying awesome lights.
In my view, LEDs are already brighter than they need to be because, in my experience, they give no meaningful level of improved visibility over halogens.
In my view, LEDs are already brighter than they need to be because, in my experience, they give no meaningful level of improved visibility over halogens. I'd be interested to see whether there's any research showing that brighter LED lights are actually of a safety benefit?
Or are you trying to argue that they go beyond what is required to see effectively at night? Seems like a weak argument because good visibility is vital. Halogen lights on an unlit rural road are barely adequate in my experience. Decent LEDs will light up to a much further distance allowing for much quicker reaction times.
On the one hand I agree having £2k a pop lights on the front of any car is ridiculous. On the other hand in 24 years of driving I've never had to replace a headlight unit.
Yes, that's what I'm saying. In my experience, Halogens provide more than enough light to react to anything ahead, they already light up my entire breaking distance, and usually as far as I can see on the roads I drive on. I don't even bother with full beams most of the time these days because dipped provide all the light I need. The LEDs on my old car were brighter, sure, but that didn't let me see anything I can't with the halogens on my current car.
Anyway, I think this is enough of a digression. I'll leave you all to disagree with me.
There are good reasons why halogens are being replaced by led's, the first, and most important, is their power consumption. When manufacturers are chasing every power drain placed upon a power unit, be it electric or ice, it is very important to try and reduce as much as possible any electrical load by any component. This is particularly important for ev'sYes, that's what I'm saying. In my experience, Halogens provide more than enough light to react to anything ahead, they already light up my entire breaking distance, and usually as far as I can see on the roads I drive on. I don't even bother with full beams most of the time these days because dipped provide all the light I need. The LEDs on my old car were brighter, sure, but that didn't let me see anything I can't with the halogens on my current car.
i agree xenon were excellent and mentioned as much earlier in this thread.....[
thought it was xenon that was the sweet spot - why did they have to die ?
none of that useful matrix tech - but lot's of lumens & bulb replaceable; but I guess the system cost was never reduced to the level of the cheap/vanilla led units.
was the power consumption and implications for other alternator etc. too big. (At home metal halide bulbs 75W 6000lumens, puts the leds to shame in light quality/cri too)
1 thing i do hope..... My car has the extended JLR warranty and i do plan to keep it..... I hope they would not try to argue that light clusters are a user replaceable part and so not covered under warranty. i mean, this is the case for all other lights, but not the case for these!.
i read that and thought it seemed a driver error. not only did the car wildly go wrong in 1 direction, it seemingly did a full on "Christine" and went proper rogue.Not sure if this has been posted, but it's another example of the media being completely wrong. This isn't even an EV.
Almost certainly driver error and he's blaming the car.
Hybrid Jaguar goes 'rogue' and reverses into a Porsche
Business owner Andrew Key was powerless to act as his £47,000 Jaguar E-Pace suddenly reversed at speed into a Porsche Boxster parked behind him.www.dailymail.co.uk
However.... as for not an EV, its a PHEV i think which still keeps it firmly in the sights of the EV hating oil funded right wing media sadly.
oh i stand corrected then!......I don't think it's even a plug-in, it's a 48V 'mild hybrid'
i guess what you lose is the ability to control different sections of the light so you can have high beam but draw a silhouette around cars you are following etc. Its a great system and works better than i could ever have imagined.2013 onwards BMW 5 Series with Xenon headlights and automatic high beam had a similar system which provided largely the same result. The same system was also used when they moved to LED headlights. So you can still have a system that works in that way with Xenon headlights.
