MSI Afterburner - Geforce Experience - Display settings
15 Mar 2007
I have Geforce experience showing me some counters (OSD) stuff and it works ok.
Tried MSI Afterburner with Riva Tuner to show some but it wont show them?
Anyone else had an issue with these counters not showing
If you want to revert back to before using oc scanner to oc your card then just rename profile folder to profilebck in the install folder.
You need to enable what you want to see on the OSD in Afterburner, these days I find myself using Nvidia Frameview more than afterburner / rtss.
Frameview doesn't give you a per-CPU core breakdown though does it like RTSS does? Cannot see anything about it in the documentation.
I much prefer RTSS for the distinct granular breakdown of what is using what:
From here:
Open MSI Afterburner: then click on Cogwheel on the left
Settings > Monitor > Active Hardware Monitoring Graph
Checkmark these: GPU Temperature, VRM Temperature, GPU Usage, Memory Usage, Core Clock, Memory Clock, Power, CPU Temperature, CPU Usage, CPU Power, RAM Usage, Framerate and Frametime
Go Under Frametime > Show in On-Screen Display > Select text, Graph
Go to top menu then On-screen Display then Toggle On-Screen Display > set it to ctrl + f12
Now go into Rivertuner Statstics Server > Setup > Enable Frametime History overlay
Now play a game and use ctrl + f12 to show fps
