GoW runs on DX11 and for whatever reason runs like trash on both Nvidia and AMD cards for some people and others of both camps found it ran great for them.My friends. I don't know where else to go.
Supposedly this card can reach clock speeds of over 2500Mhz, but when playing GoW at 1080p i can't seem to maintain 60fps, and that tickles me in the wrong way, so i started trying things.
a) Use Vulkan API mod from nexus mods: 60fps, but constant stuttering when loading new areas. Discarded, since it ruins the experience even more.
b) Tried monitoring with the AMD adrenalin software, which also lets you overclock and undervolt
Results: The GPU clock never goes beyond 1600Mhz. When i saw this i was blafergasted. I couldn't believe it. I disabled UPLS and it didn't fix that. I overclocked. Nothing fixed my problem. I just wanted constant 60fps... At 1080p that should be a piece of cake right?
Could it be possible that the problem is the MEMORY CLOCK? Why is the main clock not getting "squeezed"?
The best way to experience this game for me was under DXVK on Linux where shaders are preloaded before ever playing the game.
My bad;
MB: GIGABYTE Z270 HD3
CPU: I7 7700K Oc'd to 4,6
RAM: 32GB DDR3
Disk: 1tb NvMe msi 480 pro
I had the same issue with my setup in my signature below.his pc specs were holdding back is xtx in a big way
7700k is starting to show its age in 2024, quad cores dont really cut it thease days unless playing older less demanding titles
Assuming you do not care about RT that much then the XTX murders the 4090 in value.The last gen £2000 RTX 3090 TI almost makes an RX 7900 XTX for £800 seem like an OK price, considering the XTX is a notably faster GPU.
Realistically, I doubt we will see the price of these cards drop to £700.
It's truly nuts that the Nvidia's flagship RTX 4090 is only around 20% faster than the XTX. There's almost no difference in memory bandwidth, between the two cards.
How happy are you 7900 xtx owners with amd? I currently have a 3080 that i can probably sell for 600£ and I can get a 7900 xtx asus tuf for 900£ almost brand new with warranty. Seems like a no brainer to me? a 4080 is around 1200£ where I live.
No real surprise, some folks drink the koolaid.People aren't buying 3080s for £600 are they....?![]()
Me personally have never owned an Nvidia GPU. Going back to 2003 only ever Radeon cards. Just better value.No real surprise, some folks drink the koolaid.
I've had both cards mate and the XTX is a great option, still retains almost the rasterization power of a 4090 if you're not too bothered about RT gubbinsHas anyone switched from a 4090 to 7900xtx? might be selling my 4090 just looking for some quick opinions, this will just tide me over until 5090 if so.
Yeah I'm pre-emptively trying to get rid of it, just to minimise my overall losses really, I also haven't needed the raw power of the 4090 for the most part either, but it's still nice to have the overhead for when you do, and knowing even if you wanted to, there is nothing else better availableI've had both cards mate and the XTX is a great option, still retains almost the rasterization power of a 4090 if you're not too bothered about RT gubbins
I've only got a 90 due to it only costing me a few hundred over the 80 I used to have, it is proper overkill for my needs tbf. Blackwell rumoured to be hitting sooner than expected so I may do the same at some point.
You mean you willI've had both cards mate and the XTX is a great option, still retains almost the rasterization power of a 4090 if you're not too bothered about RT gubbins
Yeah June-ish I think, don't do a lot of gaming in summer anyhow.You mean you will![]()
